Which speakers to replace ML speakers??
Old 07-04-12, 01:29 PM
SSxblazer
SSxblazer's Avatar
Default Which speakers to replace ML speakers??
Searched and found nothing but ML sub drop in threads.
What speaker specs do I need to replace the ML small speakers? I am Dynomat'ing the car and found that some of the speakers are no good.
thanks!!!!
Old 07-05-12, 02:25 PM
1sWt2GS
1sWt2GS's Avatar
what exactly did u search?
for a start 6.5" should fit all around with adapters (ebay or make your own)
Old 07-05-12, 03:56 PM
SSxblazer
SSxblazer's Avatar
I searched for speaker replacement.
And adapters? What kind? I was thinking of just by-passing the amp and get a 4 channel and such.....
But if there are drop in replacements I would do that too. What ohm are the speakers stock with ML system?
Old 07-05-12, 05:02 PM
SSxblazer
SSxblazer's Avatar
And I still searched before and cannot find a how-to change the subwoofer settings in the Nav unit.....2003 gs300
Really would be nice for some helpful replies.
Old 07-05-12, 06:13 PM
robertoyou
robertoyou's Avatar
not exactly sure what u mean by subwoofer settings in the nav? theres a secret menu you can get to where u can get extended features. iv never done it because i found no reason to and because i didnt wana mess anything up. but there is definitely a how to on this here.
... 6.5 speakers fit all round with adapters you can buy from ebay/online. there is one specific website. the guy makes them and sells them both direct through his site or through ebay auctions. i think its speaker adapters.com google it . should be super easy to find..
idk if there are direct drop in speakers but im sure if u find the same sized speakers as the stock ones, you can drop them into the enclosures in our doors. i have the non ML and they are 4 inch speakers all around.
Old 07-05-12, 06:22 PM
SSxblazer
SSxblazer's Avatar
That's the part that concerns me.
However, if I wanted to bypass the ML amp......and get a decent 4 channel......will I need anything special? Or just put the amp in place and plug-n-play?
And I will get those adapters so I can shove 6.5's in there.
Any brand recommendations? I have an employee Best Buy discount (half off) so I was thinking Polk audio for the 6.5's
Old 07-05-12, 06:56 PM
robertoyou
robertoyou's Avatar
if youre not going for any audio thats TOO fancy then yeah i guess some polks or infinitys kappa perfects would be good enough. otherwise u might be able to get something better for similar amount
if you want to get a four channel u can do one of three things:
1. get a deck or double din to get singal to ur amp(s)
2. get a loc for the highs and for lows.
3. get a processor for integrating factory sound (essentially the same as a loc. just fancier. and also the route i went)
i would recommend the adapters. much easier to find speaker sizes in 6.5s and 5 1/4. they sell adapters for both. but u might as well go with 6.5s while ur at it.
Old 07-05-12, 07:27 PM
SSxblazer
SSxblazer's Avatar
Dont LOC's attenuate the signal?
What kind of processor for integrating factory sound did you use? Link?
What is truly the easy way that won't distort the sound much?
Old 07-06-12, 02:50 AM
VIPatrick
VIPatrick's Avatar
your are dynomating your car and routing powercables for an aftermarkt amp through the interieur...
Basically you will have to rip the whole car appart.
There is no reason to stick to the oem parts with all that time spend.
Go all in.
Find a decent headunit and route a set of Chinch and Speakercable to the trunk.
The headunit ist the key for a good soundsystem.
6.5 all around and a nice 12" sub in the trunk will make more fun than any hybridsolution with the OEM navunit because of its low current output (below 1 Volt. a good headunit dishes out 6,5 V to the amp)
Polk is fine unless you want to break some DB Dragrace.
jlhowser
02-22-19 11:04 AM
a1rh3adsz
11-10-17 12:44 PM
lilmanrock
05-27-11 08:29 PM
RuninRoach
05-06-11 12:54 AM
sjl
12-26-10 07:13 AM
Quick Reply: Which speakers to replace ML speakers??
