How many PSI?
Old 06-23-12, 07:13 PM
818GS
818GS's Avatar
Default How many PSI?
I am running 255/35/18 in the front on 18x8 wheels and 275/35/18 on 18x8 wheels in the rear. How many psi should the 255's be running? 275's?
This is my daily driver so I don't want it too rough. The tires are W and Y rated.
Old 06-23-12, 08:36 PM
Hardrvin
Hardrvin's Avatar
Depends less on size and more on the tire and your driving preference. I typically run most tires between 32 and 38 psi.
Old 06-23-12, 09:19 PM
lexo98
lexo98's Avatar
If your trying to calculate it based on the OE wheels you will need to know the load index of the 18's. It will say something like 94w after the tire size
Old 06-24-12, 12:27 PM
Mike813
Mike813's Avatar
On my 18's I keep it at 36 I would keep it at 34 if you have nice roads.
Old 06-24-12, 09:42 PM
BayAreaLex
BayAreaLex's Avatar
32psi typically is what I use.
Old 06-24-12, 11:47 PM
lunatyk
lunatyk's Avatar
You should not be putting a 275/35 on a 18x8... I hope that's a typo. I honestly wouldn't even run a 255/35 on an 18x8 either.. 255/35 recommended width is a 8.5"
Old 06-24-12, 11:57 PM
chicov8
chicov8's Avatar
recomended is probably 32psi
i do keep 32-37psi
Old 06-25-12, 12:42 AM
818GS
818GS's Avatar
HAHA thats not a typo. I gottem to fit
Old 06-25-12, 01:03 AM
2GSC300
2GSC300's Avatar
I'd do 34-35psi cold, because it will jump about 2-3psi after you start driving
Old 06-25-12, 10:01 AM
GS4_Fiend
GS4_Fiend's Avatar
35-40 depending on the tire MAX psi rating
Old 06-25-12, 11:18 PM
818GS
818GS's Avatar
The max psi rating is 55psi
Old 06-26-12, 01:43 PM
2GSC300
2GSC300's Avatar
Pls don't put in 55psi.
Old 06-26-12, 01:45 PM
671gs
671gs's Avatar
35-40 psi .....
nagooyin
10-07-21 09:13 AM
Gvr4
SC- 1st Gen (1992-2000)
05-27-08 07:08 AM
WillX
Wheels, Tires & Brakes Forum
04-18-08 09:20 PM
uplusd
07-08-07 10:02 PM
DaveGS4
09-03-02 02:15 PM
Quick Reply: How many PSI?
