Sensitive fog light switch!
Old 05-22-12, 07:37 PM
LudeNsoL
LudeNsoL's Avatar
Default Sensitive fog light switch!
So Ive had the fog light mod for a while now and just the other day I noticed that when I put my turn signal on the fog lights turn off then come back on. I saw that the fog light switch is really sensitive and when ever I touch the headlight lever it triggers the fogs to turn off and come back on. Any suggestions on what it could be?
Old 05-22-12, 08:42 PM
MadTyte
MadTyte's Avatar
Whats the fog light mod? But mine been doin that often. Now its ok but i it will start doing it again after awhile and i have to leave it for for a long while before it works ok again. I dont know, its just weird
Old 05-22-12, 08:43 PM
MadTyte
MadTyte's Avatar
Leave it off**
Old 05-22-12, 08:44 PM
MadTyte
MadTyte's Avatar
Or sometimes it would just flicker really fast
Old 05-22-12, 09:04 PM
rgarjr
rgarjr's Avatar
its probably the switch just worned out.
Old 05-22-12, 09:45 PM
randee973
randee973's Avatar
yep i have the same issue... worn out switch... ur best bet is to change out that whole switch...
Old 05-22-12, 10:08 PM
1sWt2GS
1sWt2GS's Avatar
check to make sure everything is still connected and not melted! we had some members on here who did the mod and didn't use thick enough wire
Old 05-23-12, 03:05 AM
LudeNsoL
LudeNsoL's Avatar
Thanks Everything going to the fuse box is good and still connected. Im going to check going to the switch by the steering wheel. And yes sometimes it doesn't come on I have to keep turning it off and on for it to work again.
Old 05-23-12, 09:33 AM
GS4_Fiend
GS4_Fiend's Avatar
Re wire your own switch. Cheap and easy.
Old 05-23-12, 10:10 AM
LudeNsoL
LudeNsoL's Avatar
Any suggestions on a good place to put it??
babiibryan
04-24-18 03:04 PM
GAISF
IS F (2008-2014)
10-27-16 11:22 PM
818GS
09-20-12 02:22 AM
bhbiv
Lighting
04-12-11 11:54 AM
slk_dds
05-11-07 11:59 PM
Quick Reply: Sensitive fog light switch!
