aftermarket trunk alignment
Old 05-22-12, 06:01 AM
JamesV
JamesV's Avatar
Default aftermarket trunk alignment
i just recently put a VIS Carbon Fiber trunk on my 2gs, and having trouble getting it to sit flush on both sides. any ideas?
Old 05-22-12, 06:25 AM
lowKut
NELOC Moderator
lowKut's Avatar
interesting, I have the same issue on the left side...
Old 05-22-12, 10:39 AM
vwynn
vwynn's Avatar
remove the tension springs maybe?
Old 05-22-12, 11:34 AM
JamesV
JamesV's Avatar
Default left side
mine is also on the left side. i have tried taking to springs off both sides but still not flush. was thinking about having my buddy get in the trunk and try to align it while it was closed.
Old 05-22-12, 11:35 AM
JamesV
JamesV's Avatar
is your trunk VIS?
Old 05-22-12, 01:10 PM
JeffTsai
JeffTsai's Avatar
Unfortunately, there really isn't any real adjustment back there. There might be like a few mm of movement, but they built these cars with pretty tight tolerances from the factory so there is no need for adjustments like these. When you go aftermarket the parts aren't made to the same standards as OEM so it will sometimes cause fitment issues.
I suggest you to try to keep messing with the bolts attaching the trunk to the hinge. There are also these rubber stoppers in there you can possibly try to tweak or adjust. You can even buy some rubber pads from the hardware store and stack on top of the rubber pads to increase spacing.
Old 05-23-12, 10:29 AM
JamesV
JamesV's Avatar
Default spacing
the spacing is fine. i just need to get it to sit flush on both sides. the right side sits flush, but the right side sticks up 1/8".
Old 05-23-12, 06:56 PM
TTurboPimp
TTurboPimp's Avatar
I have the same trunk, i was actually suprised at how well it fit. Its not perfect, but pretty damn good. You can also use small washers to space it where the trunk bolts up.....although it sounds like your problem is too high, not too low.
Old 05-23-12, 08:24 PM
JamesV
JamesV's Avatar
Yes the driver side sits to high....
Old 05-23-12, 08:25 PM
JamesV
JamesV's Avatar
Do you have pics?
Old 05-24-12, 12:07 PM
jriggs
jriggs's Avatar
As with any aftermarket truck you're going to need to devote a day into making it fit. The adjustment is in how you bolt the truck down. When I had a CF VIS truck we had shim on one side to even it out, before the shims one side looked to be "flush" and the other "poped up" after the shims both sides looked properly aligned. Dedicate Saturday to drinking beer, sitting back, and saying, "well we need to add two washers to the left" "nope just one" etc. Beer is required for proper fitment of aftermarket parts without it they will not fit.
Old 05-24-12, 12:53 PM
JamesV
JamesV's Avatar
Default got it
haha....yeah that sounds like something im going to need to do. thanks for the info
trinhtd
12-02-18 09:05 PM
RKSTRAT
06-26-18 03:12 PM
czr73
09-25-15 06:27 PM
09LS460
04-30-12 06:01 PM
agent Lex
04-08-09 12:13 PM
Quick Reply: aftermarket trunk alignment
