LED drl upgrade
Old 05-08-12, 06:50 PM
  #31
JamesV
JamesV's Avatar
Default Color
[QUOTE=MrG4Life;7219109]I assume the bulbs you bought were the Xenon White?
Yes the color is the xenon white.
Old 05-08-12, 09:44 PM
  #32
Feijai85
Feijai85's Avatar
Did you only need the harness for this mod or did you also need the resistor that vleds requires?
Old 05-09-12, 01:21 PM
  #33
JamesV
JamesV's Avatar
Default led lights
i bought mine IJDMTOY.com and it came with harness and what they call decoder(resistor) so all you have to do is plug and play.
Old 12-03-12, 09:36 PM
  #34
namngo
Registered User
namngo's Avatar
http://www.ddmtuning.com/Products/9005-LED
Will this work on the car as well? It's a super cheap replacement compared to the one you got. Has anyone tried these or know anything about these?
Old 12-04-12, 06:29 AM
  #35
4eign
4eign's Avatar
OP i have the same and love em.
Old 12-04-12, 09:20 PM
  #36
veron1987
veron1987's Avatar
looks nice on the car close...Should post a pic out in the daylight
Old 12-05-12, 01:17 AM
  #37
Lazy
Lazy's Avatar
Anyone try putting some hids in the drl?
Old 12-05-12, 03:33 AM
  #38
ClarisaRWD
ClarisaRWD's Avatar
I wanna make my drls yellow
Old 12-05-12, 10:04 AM
  #39
nar8ta
nar8ta's Avatar
Doesn't the daytime running lights work on 1/2 the power of the highbeams....how does this work? Doesn't the leds need fulll power. I can understand the LEDS working on the highbeams but what about the daytime running lights.
Old 12-05-12, 10:22 AM
  #40
marcman804
marcman804's Avatar
I would like to get these but I need my highbeams here in VA with all the deer running about. Are there any alternatives?
Old 02-06-13, 07:21 PM
  #41
Jblkstr
Jblkstr's Avatar
Anyone know if that will work with halo lights
Old 02-08-13, 07:45 AM
  #42
LandonGs03
LandonGs03's Avatar
I did this replacement too. It was a direct swap with the high beams. I was stupid and got the blue lights and if you are thinking about doing this from ijdm.com the blue ones are very illegal. They look good but it is a pain and now im regretting doing this cause I need my high beams. Plus to use them you have to keep your high beams on so they dont run naturally during the day.
Old 02-08-13, 09:32 PM
  #43
Mikerx80
Mikerx80's Avatar
Namngo. The DDM LED products are actually decent. I had spent a lot of money in the past with my JAG S-Type got the full PHILLIPS HID headlight system for $500. Got the DDM system for pennies for my GS and can't tell the difference. Also they offer lifetime on their merchandise. You can't go wrong with that. For the DRL I actually put in PIAA bulbs looks pretty classy with a little goldish tint when on, when you light up the high beam it turns bright WHITE similar to LED but not quite. But I have noticed it helps when high beam is needed. Although the DRL/LED looks nice it's quite annoying for the others on the road, IMO.
Old 02-08-13, 09:35 PM
  #44
imherenow
imherenow's Avatar
can you take some pictures but during the day
Old 02-08-13, 10:31 PM
  #45
paul1012
paul1012's Avatar
looks nice !
XCLSVELS
12-26-19 08:36 AM
chris07is
02-21-14 07:42 AM
Ken300
01-21-11 10:47 AM
GordoNx3o9
10-16-07 11:30 PM
Quick Reply: LED drl upgrade
