whistling noise after drop!!!!
Old 04-29-12, 12:36 AM
mlor12
mlor12's Avatar
Default whistling noise after drop!!!!
Hey guys afyerwards searching couldn't find anything similar to my problem. Just got some ez streets, installed them n now whenever I go above about 40 I start hearing a whistling from what seems like the front drivers side wheel well. Idk wat it is. It also makes the noise when I do wide turns going anything above like 20. Any ideas what it is? Is it just wind noise on tires? Keep in mind I'm still on stock 16s. Dropped so u can stick one finger in at an angle. N also after dropping my abs vsc n vsc off came on.? Well im assuming we probably messed up one of the sensors? Need help very annoying both of these problems.
Old 04-29-12, 01:23 AM
1sWt2GS
1sWt2GS's Avatar
a video should help with the problem
Old 04-30-12, 01:23 PM
mlor12
mlor12's Avatar
I think I figured it out. Had also changed outter tie rods so might just be really bad alignment causing tires to squeal. Getting align if still persist will post up video.
CBNCLexus
03-30-24 08:43 AM
Ryandthach
RC F (2015-present)
15
07-18-18 06:03 PM
Lexus083
IS - 1st Gen (2001-2005)
03-12-18 07:10 PM
charlielin
08-21-14 05:52 PM
maximakid
07-16-13 05:37 AM
Quick Reply: whistling noise after drop!!!!
