Changed Transmission now I have slight vibration
Old 04-17-12, 10:41 AM
2jzgttegs
2jzgttegs's Avatar
It was the motor mounts guys... No more vibration!!!
Old 04-17-12, 10:57 AM
mexikan
mexikan's Avatar
Thumbs up
glad to hear you fixed your problem
Old 04-17-12, 10:59 AM
Debonair
iModerate
Debonair's Avatar
Awesome, glad to hear it is fixed.
GS4_Fiend
GS4_Fiend's Avatar
Looks like i hitted the target.
Old 04-17-12, 11:03 AM
2jzgttegs
2jzgttegs's Avatar
Thumbs up
Yes you did!!! Good job
Old 04-17-12, 11:05 AM
2jzgttegs
2jzgttegs's Avatar
One more thing that's crazy is, the mounts didn't even look bad
Old 04-21-12, 01:27 PM
2jzgttegs
2jzgttegs's Avatar
Vibration came back!!!! Found out last that the crossmember for the transmission was preloading on the mount. I guess the A3040 trans & A340e has different mounting locations.
Old 04-21-12, 01:29 PM
2jzgttegs
2jzgttegs's Avatar
Does anyone know what crossmember to use on a A340E from a supraTT in a GS
Old 02-16-13, 11:33 AM
G0TB00ST
G0TB00ST's Avatar
Did you get this figured out? i am having the same problem...
Old 02-18-13, 06:36 AM
2jzgttegs
2jzgttegs's Avatar
I had to get the correct crossmember for the transmission. Because the holes wasn't lining up. The shop that installed the transmission forced the incorrect crossmember and that cause the trans mount to preload really bad which caused the vibration. I got the correct crossmember and I installed it... problem solved no mor vibration.
93sc400nm
Performance & Maintenance
08-02-17 07:52 PM
Eds98LS
03-30-13 08:27 PM
cartmill
04-01-12 02:00 PM
djpolak
05-08-09 09:24 PM
Quick Reply: Changed Transmission now I have slight vibration
