Modify steering ecu DIY
Old 04-19-12, 08:32 AM
YviE
YviE's Avatar
Will post a review once I have installed it.
I bought a second ECU, just in case I screw this one up.
Old 04-19-12, 11:11 AM
justablkv8
justablkv8's Avatar
You in a gs3 or gs4?
looking at getting this other ecu in the uk (cheaper than what it cost me here).
Old 04-20-12, 01:14 AM
YviE
YviE's Avatar
I got a 99 GS3.
Yeah you can find them cheaper in the UK or Germany.
Old 04-20-12, 07:32 AM
justablkv8
justablkv8's Avatar
^ Find me a brake master cylinder and i'll throw some cash your way. haha.
Old 04-20-12, 07:33 AM
YviE
YviE's Avatar
2001+ model you're looking for I guess
Old 05-07-12, 03:04 PM
YviE
YviE's Avatar
Before installing, I adjusted the potmeter:
3.2 kOhm, instead of 4.62 kOhm (stock, 560 ECU)
Old 05-08-12, 06:14 AM
justablkv8
justablkv8's Avatar
Yes SIR! you are correct!
Old 07-27-12, 03:10 AM
JeffTsai
JeffTsai's Avatar
I wonder if someone with the L-Tuned ECU can shoot a picture of the internals. Like a really high res shot. Maybe we can compare the different resistor values inside the boards. I can snap some pix of mine from my 2002 SportDesign and the 2005 GS300. Then we can compare it to the L-Tuned. If it's just a simple resistor difference, then we can just all drop in the resistor value of the L-Tuned ECU.
Old 07-27-12, 08:30 AM
sakataj
sakataj's Avatar
i probably can.....i just bought a L-TUNED steering ecu and allegedly the GS430 steering ecu is the same but it may not be
Old 07-27-12, 10:53 AM
str8lucky
str8lucky's Avatar
Where is best place to buy the ECU? Or just go to Junk Yard???
Old 07-27-12, 03:03 PM
YviE
YviE's Avatar
Yeah or ebay.
Old 07-29-12, 11:37 PM
YviE
YviE's Avatar
Just for your info, 3.2 ohm is too low. Steering is underpowered and needs quite some effort. Need to tweak the adjustment a bit.
Old 07-31-12, 09:14 AM
GSquicksilver
GSquicksilver's Avatar
any update on this?
let's get the color codes of the resistors in the l-tuned and the 2 that jeff had and figure this one out. the steering ecu looks like a pretty simple design actually, and probably want to change out the 2 electrolytic caps while we're at it since they might have drifted in value over the years.
Old 08-21-12, 09:09 AM
GSquicksilver
bump...
sakataj: did you get a chance to shoot pics of the internals of the l-tuned ecu?
Old 08-21-12, 12:46 PM
sakataj
sakataj's Avatar
Originally Posted by GSquicksilver
bump...
nope couldnt get case open without cracking it so installed it and sold my GS430 steering ecu
Quick Reply: Modify steering ecu DIY
