Shaking at 60mph cured???
Old 02-02-12, 09:39 AM
Pusha100
Pusha100's Avatar
Originally Posted by GS4_Fiend
Lower Control Arm No.2 would be next
Hi,
Thank you for the input
Is this the correct part you are referring to "lower control arm"?
http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
Old 02-02-12, 09:54 AM
GS4_Fiend
GS4_Fiend's Avatar
I would recommend getting OEM ones. LCA #2 looks like an S, not like that
Originally Posted by Pusha100
Hi,
Old 02-03-12, 05:23 AM
whitegs84
whitegs84's Avatar
Deffinately agree with gs4. Got an outer tie rod from eBay once and it was like an inch longer than OEM. Idk if it makes a difference but I just did trust it so ended up buying oems.
Old 02-03-12, 11:50 AM
Pusha100
Pusha100's Avatar
Thank you both for the help!! And you are right, I will go OEM
Also if the shakes still remain after that what's the next step? lol
Old 02-03-12, 06:56 PM
LexiBlue
LexiBlue's Avatar
im replacing my control arms
Old 02-03-12, 08:18 PM
Pusha100
Pusha100's Avatar
Hi,
Can you please let me know if the shakes go away once your control arms are installed or if there's is at least a big improvement?
Old 02-03-12, 09:19 PM
GS4_Fiend
GS4_Fiend's Avatar
Hi,
Before changing any suspension part, make sure it's bad before changing it. If the suspension has bushing, check to see if they are cracked and use force to wiggle it and see if theres play. If bad, then change.
Old 02-14-12, 01:03 PM
dmc_maine
dmc_maine's Avatar
While I know that it is important to replace any worn suspension parts if they are in need of replacement, I never really solved my 60mph shake until my tires were replaced. I fixed everything else until it was time to replace my tires then I bought a set of Conti ExtremeContact to replace the cheap junk that the seller used so that he could say that the car had "new tires" when he sold it to me. Once the Conti's were installed everything came together like I expected it to. My recommendation is to buy the highest quality tire that you can afford.
If you're not using OEM wheels then my advice might not apply since I keep my cars completely stock.
Good luck!
Old 02-15-12, 04:38 PM
Pusha100
Pusha100's Avatar
Hey Guys,
Going to pick my car up later today, got my front upper & lower control arms replaced (previously in the thread my ball joints as well) Hope this solves the problem.
I will reply later on tonight w/ the results, wish me luck
Old 02-15-12, 05:54 PM
tiger4life
tiger4life's Avatar
Could be anything on these suspensions that cause shaking. I just adjusted the damping on my megan ez coilovers for the 1st time and it significantly reduced the shaking. I thought they were set to soft and it turned out they were set to hard!
Old 02-15-12, 07:27 PM
DosyBoy
DosyBoy's Avatar
Originally Posted by billzblaze
Ok so ive been hearing alot about the bushings being bad or the castor arms needing to be swapped to newer ones due to the shaking.Well my car would ALWAYZZ shake at 55 to 65mph i have a 98 GS400 and yesterday i had some new tires put on with a balance and alignment and guess what no more shakes i was bout ready spend some cash swapping suspension parts out.Has anyone else experienced this with a regular balance and alignment???So i just hope i didnt speak too soon and it doesnt come back...
I'm doing this next, I sure hope it works!
Old 02-15-12, 09:26 PM
Pusha100
Pusha100's Avatar
Hey,
Do you have a tutorial on how to adjust the damper settings?
Much appreciated
Old 02-15-12, 10:44 PM
DosyBoy
DosyBoy's Avatar
I wonder if we all call Lexus the same day and bombard them for a few months straight, maybe we could get a late recall on the suspension seriously the shakes suck! I actually have a paper from a Lexus mechanic saying what to do first and so on and so forth, there's like 5 of them, and supposedly if you do these in this certain order your shakes will be gone for good.... you guys want me to post it here? Or make a new thread? I think it could be very helpful..
Old 02-15-12, 11:01 PM
Pusha100
Pusha100's Avatar
Hi,
Yes please post them, thanks for the help
Old 02-15-12, 11:09 PM
DosyBoy
DosyBoy's Avatar
This is based on research through Lexus techs, follow the below list in that ORDER:
1) Alignment (very important)
2) Road Force Balance (very important)
3) Wheel Hub Adapters (very important)
4) Replace Ball Joints (recommended)
5) Replace Tie Rods (recommended)
6) Replace engine mounts and transmission mounts (recommended)
7) Replace Caster Bushings (recommended)
8) Replace Wheel Bearings (last precautionary step)
If you follow the above list in that order, I GUARANTEE if you follow that list in ORDER, at some point the shaking will stop.
Quick Reply: Shaking at 60mph cured???
