seat belt issue???
Old 11-30-11, 12:39 AM
Fiend
Fiend's Avatar
Default seat belt issue???
okay so my driver side seat belt is not going back in like its suppose to, after i release it...it will just hang there all loose and i have to help push it back in...and when i put it on it will not tighten up to me it will just kinda hang there over my shoulder....how would i go about fixing this issuse???thanks...
Old 12-03-11, 10:46 AM
Fiend
Fiend's Avatar
i take it no one has this issue?
Old 12-03-11, 11:40 AM
fuzzzz
fuzzzz's Avatar
I had this issue. Use baby powder and apply it on both sides. Makes it stick more. I know it sounds weird, but it worked.
Old 12-03-11, 04:28 PM
zmw
zmw's Avatar
the issue is that the spring is worn out, you can either take it apart and rewind the spring or repace the seat belt... happens on nearly every toyota vehicle more than 10 years old....
Old 12-04-11, 03:48 AM
Bombsquad
Bombsquad's Avatar
Are your seatbelts dirty? Very Dirty. My ivory interior ones were soiled, so I unbolted them at the seat base end, then pulled them out as far as they could go. Then i shut the door on them to hold them outstretched. Then i sat them in a bucket (which was sat on a table outside the car door) of cleaning solution over night. Then i put a nail up, hooked them up so they were stretched out taught and used my water pressure blaster on them. Let them dry and the look and feel like new.
Old 12-04-11, 04:40 AM
YviE
YviE's Avatar
Common problem on Preludes, dirt was often the problem. Try cleaning the belt and hinges.
Old 12-04-11, 09:57 AM
G2LEXO
G2LEXO's Avatar
Yep, I'm having the same issue.
Old 12-07-11, 01:30 PM
RamAirRckt
RamAirRckt's Avatar
Yup, me too, figured it was "normal", this is my first Lexus and most Japanese cars I have been in have lame seat belt retractors. Not one of my GM cars ever did. Just thought it was normal.
BobbyT
RX - 1st Gen (1999-2003)
20
11-07-21 05:57 AM
KarenAnne
02-11-19 09:17 AM
TheLazyC
ES - 6th Gen (2013-2018)
12-23-15 06:16 PM
titleistek
07-21-15 09:59 PM
Norbecke
02-24-14 04:54 PM
Quick Reply: seat belt issue???
