Cel on (again)!!
Cel on (again)!!
Recently I had the sputtering and violent jerking when accelerating. CEL on, blinking, VSC and VSC Off dash lights. Codes were showing up misfires. Changed all spark plugs, wires, valve cover gasket (leaking oil from side), some intake gasket, throttle body cleaned and decarbonization of engine...Car's driving great but now my CEL just popped up and throwing codes P0153 and P0150.
* Heated Oxygen Sensor - Bank 2 Sensor 1 - Circuit Slow Response
* Heated Oxygen Sensor - Bank 2 Sensor 1 - Circuit Malfunction
Any thoughts where to start on this? I searched and seen some people say its a sensor and others saying its not related to the sensor...Should I just replace the sensor? Anybody have the part# for this sensor and location so I can install myself...
Thanks,
Thanks,
iModerate
If these are the only two codes you are getting there is a really good chance it is the sensor. Check the wiring and plug leading up to the sensor and then replace it.
There are ways to test the sensor using scan tool data and/or a multimeter. This may not be worth the time and cost if you are not doing it yourself.
Pics Of Location Of Oxygen Sensors
Luscombe8A
05-03-18 06:48 PM
