How much will it cost for 2JZ Twin turbo for GS300
Old 11-13-11, 06:32 AM
alloys999
alloys999's Avatar
Default How much will it cost for 2JZ Twin turbo for GS300
and will i get it auto transmission
Old 11-13-11, 05:48 PM
MrExecutiv
MrExecutiv's Avatar
If you're talking about swapping in a gte motor, the motor itself and auto trans will be around 2500. Then you gotta add in labor for the swap misc and maintainance parts you will need. This will depend on where you go to.
If I remember correctly when I got my swap done it was around 4-5k for the swap + labor and parts.
Old 11-13-11, 08:47 PM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
How about a LSx swap
Old 11-13-11, 08:53 PM
01LEXPL
01LEXPL's Avatar
buy a JDM front clip... it would work out cheaper that way. Someone on here is doing the same... You can get them for about 4-5k from canadian shops.
Old 11-13-11, 08:57 PM
PMP 300
PMP 300's Avatar
how long is a piece of string
what sort of power are you looking at auto/manual? single or twins? stock or BPU? Standard or aftermarket ecu? untill we know these you can be off by thousands.
Old 11-14-11, 06:16 AM
6t6
6t6's Avatar
Motor Trans and wires about $2000 + labor about $1000 + intercooler and custom install and tweeking about $1000 + $500 for misc stuff, about $4500 give or take.
Old 11-14-11, 10:02 AM
VIPdLexus
VIPdLexus's Avatar
!!! this swap sounds greatly affordable!! makes me want!
i always thought it was close to 8k with all the wiring and custom crap...
Old 11-14-11, 03:45 PM
AristoKing
AristoKing's Avatar
A stock GTE swap will run you about $4-5K but if you want more like single T and all the other goodies than the price goes up. As for the transmission if your going to use the actual aristo auto-tranny then make sure you get the right parts for the drive shaft otherwise your car wont run properly or at all for that matter.
AzGsTwan
Build Threads
29
08-17-21 05:19 AM
Arkansas
Performance & Maintenance
01-16-12 11:26 AM
1jzgte603
SC- 1st Gen (1992-2000)
13
04-15-11 09:27 PM
cricket056
IS - 1st Gen (2001-2005)
15
01-25-10 07:33 PM
Quick Reply: How much will it cost for 2JZ Twin turbo for GS300
