Hey guys I have a major problem. I have a 2000 gs300 with 165k miles now on it. I had an oil leak for a while now and I took it to get fixed. The mechanic told me it was the seals and he went ahead and changed it with all the other things as well including timing belt and water pump. A couple days later I noticed the same leak again. I took it back and they did the seals a second time and after that I still have the leak and it's even worse now. It's coming from the timing belt area behind the drive belt. Anybody have the same problem or know if it is definitely the seals or it could be something else? Thank u in advance for all ur comments.
could be the vvti gear or if he used after market seals that could be why its still leaking. if valve cover gaskets are bad you will find oil around the spark plugs.
