Weird thump from the rear when putting the car in D
Old 10-26-11, 08:00 AM
renegadeh
renegadeh's Avatar
Default Weird thump from the rear when putting the car in D
First of all hello to Lexus community! This is my first post.
Had some brake problems recently which seem to be fixed now. The problem is when I start the car, shift to D, release the brakes and the car start rolling - after 1-2 seconds I get a weird thump-push from the the rear and something at the back makes a squeeking noise right after that happens. If you gain speed the squeeking goes away. This only happens if car is parked for more then 1 hr.
Any ideas?
Old 10-26-11, 08:49 AM
maxinGS
maxinGS's Avatar
i have the same EXACT thing too!!!!...im in for this one...
Old 10-26-11, 09:20 AM
GS4_Fiend
GS4_Fiend's Avatar
Bushings from the rear carrier ia cracked. Very common on rear drive cars. Also make sure you drive shaft bolts are not loose
Old 10-26-11, 09:26 AM
cdg306
cdg306's Avatar
Yep. Also check out u-joints on the driveshaft.
Old 10-26-11, 04:09 PM
maxinGS
maxinGS's Avatar
any pics of these?
Old 10-26-11, 05:09 PM
breadbeat
breadbeat's Avatar
Engine mounts, Trans mount.
Old 10-26-11, 05:11 PM
cdg306
cdg306's Avatar
This is from a Supra but it gives you an idea.
Not sure what this is from but again gives you an idea.
J50NWA
02-12-19 07:47 AM
MHarner
Suspension and Brakes
09-22-11 12:34 AM
stylez1006
Performance & Maintenance
15
06-24-08 10:16 PM
ZeekGS300
04-24-07 02:27 PM
96sc3
12-08-06 11:13 AM
Quick Reply: Weird thump from the rear when putting the car in D
