Please help diagnose engine problem
Old 10-18-11, 04:41 PM
GS400Star
GS400Star's Avatar
Default Please help diagnose engine problem
Symptoms
1. Rough Idle
2. Loud high pitched noise coming from engine - sounds like metal on metal but I dont think it is. Maybe bad bearing sound?
3. Engine noise is there at idle and low revs but goes away as I rev the engine
4. No loss of power
5. No CEL
I looked under the hood and the noise seems to be coming from the water pump area but I cant be sure. Could a water pump make this noise if it was about to fail?
The car has 193,000 miles and the timing belt and water pump were changed at ~ 98,000 so it seems likely that the water pump would be due for replacement soon and even if it wasn't it might as well be replaced if I'm going to change the timing belt.
I made a video of the engine noise if you would liek to hear exactly what it sounds like.
Thank in advance for any help you can provide.
http://youtu.be/GB8f3g3j-c8
Old 10-18-11, 06:04 PM
TWong350
TWong350's Avatar
Wow...that sounds terrible. Where's the sound coming from? Rather, what part of the engine bay is it coming from? Front of the engine could mean it's the water pump. But, it could be a number of other things too. I take it you've checked out level and whatnot?
Old 10-18-11, 07:03 PM
GS4_Fiend
GS4_Fiend's Avatar
Smart of you making the video. Is the oil level good? What's the condition of the oil? Buy a decent vacuum gauge and get it hooked up any where on the intake manifold and see what the vacuum reading is. The reading should be a steady 18-21" of Hg. Then report back.
Old 10-18-11, 08:37 PM
clos430
clos430's Avatar
Sounds like a bad pulley, tensioner/ water pump. Remove drive belt and start engine to see if noise continues. If so most likely it's coming from the water pump. Almost 100k miles on it so i think it's time to replace it.
Old 10-18-11, 09:12 PM
DeanGS
DeanGS's Avatar
Yeah, pull the belt off and see if the noise is still there. It sounds like about 4 taps per second which equates more to a valve train issue (if idle is around 600 rpm or so). Might be a collapsed valve spring (piston hitting a partially open valve) but I've never seen that on a 1U/3U.
Old 10-19-11, 04:22 PM
Rock-a-Lex
Rock-a-Lex's Avatar
Agreed. But if its not the belt I would def check the engine oil level and its consistency. The 1uz does funny things when the oil level is too low or too high, good luck!
Old 10-19-11, 04:47 PM
Bippu147
Bippu147's Avatar
check the crank damper
Old 10-19-11, 08:00 PM
cdg306
cdg306's Avatar
Start with your tensioner. They make horrible noise when they start to go. Could also be water pump. Do you have a length of pipe like a jack handle or something? Put it up to your ear and it will help you isolate the noise to a particular item.
Old 10-19-11, 11:29 PM
GS400Star
GS400Star's Avatar
Thanks for the suggestions. This Saturday I will try and locate the issue from the suggestions here. Will check the oil too.
Thanks
Old 10-20-11, 08:36 AM
FrankT
FrankT's Avatar
Remove the serpentine belt and run the car a few seconds.
My guess is the ac compressor has a stuck valve.
Good luck and please keep us posted.
Old 10-20-11, 11:25 PM
GS400Star
GS400Star's Avatar
I assume you don't mean the timing belt. IS there a DIY write up for removing the serpentine belt?
Old 11-15-11, 02:23 PM
GS400Star
GS400Star's Avatar
Its rod knock. Car is officially dead.
Old 11-15-11, 04:18 PM
ThomasGS4
ThomasGS4's Avatar
That burns.
Any plans for a new engine?
Old 11-15-11, 04:30 PM
Bippu147
Bippu147's Avatar
or part out?
lol
Old 11-15-11, 05:04 PM
GS400Star
GS400Star's Avatar
checking with a mechanic on the cost of a used engine or the repair of the current one. What I do will depend on the cost. It was a great car until now.
Quick Reply: Please help diagnose engine problem
