Oil Level?
Oil Level?
I have a 98 GS4 and when I check the oil after overnight sit, the oil level is 4 inches over the full line.
But if I drive it and let it warm up, then let it sit for 5 min or so and measure, it is spot on.
Is this normal? Is the oil cooler (if it has one) draining into the pan?
I haven't been under it, what sort of oil filter does this have? Spin on or Canister? I saw some reference to a canister, but not sure I trust it, 99% of the cars today have spin on.
I'll look at it again tomorrow and see. I normally don't wipe it when the engine has sat over night.
I am pretty aware what stick is what.... Was glad to see the trans stick is a locking stick too.
Just recheck. If it's really 4 inches above the full mark, you need to get under your car asap and drain. This is the EXACT reason why I do things like this on my own. I've actually heard a mechanic state that the engine "soaks" up oil (like if you dip a towel in water) so he always overfill engines by 1qt...
Yikes! Find a new Mech!
I agree, I do my own work 99% of the time. Even alignments I can do at home (its simple geometry.... Don't kid yourself, you can be just as accurate as a shop, if not more so, as you will take the time to do it right)
I looked at it this weekend, high as usual cold overnight sit. Then I wiped stick, it was high, but only an inch or so, then if I check after 3-4 min after engine hot, reads spot on.
After overnight Soak engine cold.
After overnight Soak, engine cold, stick wiped and measured again.
Talked to my friend who works at Lexus, he said what I see is normal. It should be checked hot and pretty shortly after shut down. Essentially engine hot, shut down, pop hood, walk around car to open hood and check. (I believe he said he's been at Lexus for 22+ years)
Which mine reads good at that point in time.
Do we have oil coolers? wonder if the oil cooler is draining back into the oil pan and giving the high readings. I have seen my 454 do that, it drains back slow overnight and an oil change with filter will take 7 quarts then, if the cooler didn't drain, around 6-6.5 quarts.
esandes
06-21-06 07:49 PM
