FAQ: GM LSx Engine Swap into 91-2005 GS300/400/430 / 01-05 IS300 / 91-00 SC300/400
Old 09-16-11, 08:15 PM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
Originally Posted by boosted4.6
Stock f body oil pan works. No need to modify pan on an sc300 lsx swap. Just modify rear crossmember to fit. Simple. Stock fbody drive shaft works as well just buy driftmotions 1350 adaptor and a 1350 flange at your local driveline shop. No custom length needed. This is for sc 300. I don't know about the gs or is
You're correct. on the SC its the crossmember needs to be modified. GS and IS are the only two that need the oil pan modded.
here is an SC showing the oil pan clearance
Old 09-16-11, 08:17 PM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
Originally Posted by starfyrels
pricing on this swap?
get on the group buy and save some bucks!
as for the entire swap, there are so many variables. Depends what you want, that will change the total price.
https://www.clublexus.com/forums/clu...ck-it-out.html
Old 09-17-11, 01:31 AM
battery188
battery188's Avatar
Originally Posted by AMSMIKE
There are a few GS with LS1's. I don't know any others with the LS2 and DBW. I hope more people will do it
The stock brake booster has its own control unit on 01-05 GS. It's not part of the factory engine ecu and is on a completely separate harness. Meaning, when you remove the engine and harness. The Brake booster is UNTOUCHED.
Yeah, I'm looking at the wiring diagram for ABS/TRC/VSC ECU and it is connected to ECU via 5 wires pg 177 of FSM.
Is your traction still working?
Old 09-17-11, 08:39 AM
sakataj
sakataj's Avatar
Originally Posted by AMSMIKE2
I don't know anything about other oil pans and how they fit...would need to be test...Brian the oil pan tester has a good ring to it. lol
well i know alot of the other vehicles people desire that pan as its thin and will clear most of everything. it will bolt right up, ? is will it fit and work with our subframe
one of my local mechanics has a rear wheel drive civic with complete corvetter interior (including dash) motor and a procharger supercharger. google civette for info or youtube him (if u see pics/video of the car and its black they OLD, its since been painted orange/silver and now has the procharger setup and two 250 shots on it. scarriest car i ever rode in once it gets traction
he also has a WRX with a ls(x) and a 240sx with a ls(x)
anyways,i think he used that pan i suggested in one of them and notched the other 2 to fit the OEM pan. what about like a moroso or something else that would be a slimmer but wider pan like sikky makes for the 240sx crowds swap?
for cost reasons i may end up doing this as a automatic at first and build the motor then come back and switch it to a manual....would i use the same tranny mount
(already thinking about the possibility of a automatic turbo ls, less boost pressure lost with a auto) i can see it now a turboed LS with a powerglide BWAHAHAA that would suck for a daily but seriously i may start this out with a auto to keep cost down who knows. i gotta call that guy you recommended me to monday
Old 09-17-11, 10:07 AM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
I followed the civette build on Honda-Tech a few years ago. You are in good hands with him around!
The auto 4L60 / 4L65 and I think the 4L80 as well. They sit back about 3-4 inches further to the rear than the T-56. So IF you use the T-56 trans bracket, you will need an adapter to reach the trans mount.
dude, auto LSx turbo or S/C would be a rocket ship!!!!
Old 09-17-11, 10:08 AM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
ABS works. I didn't wire traction control. I have no need for it.
Old 09-19-11, 09:27 AM
sakataj
sakataj's Avatar
yeah he's crazy....
so of the three of those tranny's which is the best (most reliable also is a concern) and could an adapter be made reasonably?
can traction control be wired to work? if i can get a minute today i will call your buddy...
Old 09-19-11, 10:32 AM
AMSMIKE2
Former Sponsor
AMSMIKE2's Avatar
Originally Posted by sakataj
yeah he's crazy....
The GTO i believe has the 4L65. I am not too knowledgeable about the automatic transmissions. I would check the Camaro/Firebird/GTO forums and read up on them.
No need for an adapter. You get an auto trans that came off an LS. Or find a complete engine package that already has the trans.
I never looked into wiring traction control. I have never used it and almost every car i owned, I disabled it permanently.
if you wanted, I am sure it can be done.
Old 10-16-11, 11:50 AM
00Formula
00Formula's Avatar
The 4L80 would be the auto you would want to use with a turbo LSx engine. This is a good thread, I'm looking into a 5.3L truck engine LS swap with a turbo into some kind of Lexus at the moment. The GS and LS are better options at the moment due to under hood space and stronger rear ends that bolt up with LSD options.
Old 12-04-11, 10:14 PM
bucnasty
bucnasty's Avatar
I just bought the mounts to do a 5.3/4l80 swap in my 2gs
Old 12-05-11, 04:56 PM
blazer84
blazer84's Avatar
I'll post up some of my build pics and info when I get my trans back in the car. I was running the stock converter - it ballooned and took out the pump. I'm loving it though! SC's are awesome LSx candidates!
Old 12-05-11, 05:31 PM
AMSMIKE
AMSMIKE's Avatar
you went turbo didn't you? would love to see some picts of the build
Old 12-07-11, 05:47 AM
blazer84
blazer84's Avatar
Yup! I hope to have the trans back in the car tomorrow. I'll post up some pictures and videos soon!
Old 12-07-11, 09:49 AM
AMSMIKE
AMSMIKE's Avatar
Old 12-07-11, 12:43 PM
sakataj
sakataj's Avatar
mike....someone asked me about this yesterday. how IS the ride with these energy suspension mounts?
Quick Reply: FAQ: GM LSx Engine Swap into 91-2005 GS300/400/430 / 01-05 IS300 / 91-00 SC300/400
