Please help passenger side door handle cable broke
Old 12-30-13, 03:07 PM
islexusred
islexusred's Avatar
Default Please help passenger side door handle cable broke
hey guys just replaced my 2 front door actuators ( motor) this morning but accidentally broke the cable with the black threaded retaining cap that hooks on the front passenger door lock!!!! does anyone have a spare or know where to buy it? looked on ebay , amazon and sewell but came up with nothing
Old 12-30-13, 09:03 PM
ttaylor993
ttaylor993's Avatar
Check one of your local salvage yards. You should find one there. Be sure to check Toyota Camrys and Avalons and not just Lexus. They may even give the part to you.
Old 12-30-13, 09:18 PM
monkey92
monkey92's Avatar
you talking about the actual cable broke? or the black cap?
Old 12-31-13, 03:22 AM
islexusred
islexusred's Avatar
Good idea! do you think the parts would match?
Old 12-31-13, 03:25 AM
islexusred
islexusred's Avatar
Just the threaded black cap that hold/adjust the tension of the cable. tried super glue but it snaps right off.
Old 12-31-13, 03:26 AM
islexusred
islexusred's Avatar
Originally Posted by MonGoLMiri
pm me for one.
Do you a spare?
Old 12-31-13, 05:49 PM
monkey92
monkey92's Avatar
depending on how the black cap broke, you can try to use a paper clip or a metal wire to tie it back in place and onto the back of the handle. i had the same problem and that method worked for me. i wished i had taken pictures to show you exactly what i meant.
Old 01-02-14, 06:43 AM
sakataj
sakataj's Avatar
just a heads up you cannot replace JUST the cable. if you had searched there are threads were people used heat shrink on them and/or electrical tape to reattach it.
Old 01-02-14, 09:18 PM
islexusred
islexusred's Avatar
would you please clarify how i cannot replace just the cable? the cable itself is fine just the black retainer that secure/adjust the tension broke. and about the heat shrink would you please share the link for the heat shrink tread?
Old 01-03-14, 06:59 AM
sakataj
sakataj's Avatar
well as i said, the WHOLE cable cannot be replaced, even if you open it to the actuator and manage to get it out of the assembly safely noone sells a cable for our actuators. yes since your new your using up your freebie on a really simple solution though....take some super glue and just put a small dab on it where the black piece broke (lining it up as best as possible) then take some heat shrink cable and put it over the black piece and heat it up. next time please search before making any posts OR post this in the main actuator sticky to keep our clutter down
Old 01-03-14, 12:15 PM
islexusred
islexusred's Avatar
Thank you so much for your time! Am gonna try the combination of super glue and heat shrink, hopefully that will make it stick.
Old 01-03-14, 01:22 PM
DosyBoy
DosyBoy's Avatar
2 thumbs up....
Stinker
IS C
07-26-13 03:43 PM
PUREADDICT
06-28-12 09:42 PM
/Aerostar\
SC400 / 300 Classifieds
05-19-06 02:12 PM
knocnemdown
Maintenance
11-17-04 01:44 AM
Quick Reply: Please help passenger side door handle cable broke
