How to re-pin a harness
been here, done that
i broke another harness though but it should be the same method. i went ahead and took out the pin (that im assuming is stuck in the harness) , took out my soldering kit, and soldered the pin back to the wire.
it takes a lot of time and patience but it'll work if done right. i also ended up running to radio shack and getting a little of this adhesive stuff (forgot what it was called) because originally ONLY soldering it didnt work.
Account under Legal Action - Banned
first you'd get a camera with an auto focus, or a steady hand.
1. http://www.jpcycles.com/product/381-...utm_medium=cse
2. http://www.radioshack.com/product/in...uctId=2103252#
(not the exact pin type you'll need, but you need something similar)
3. small tiny micro flat head.
Use 3, 1 and 2. In that order.
That's what I was thinking. I'll have to try it.
get a dentist pick that what i started using til i found the tool to remove it
like this http://www.kandgcycles.com/Elec-Term...oval-Tool.html
