20x9 +15 or +35 for front
07-29-11, 11:49 AM
I'm going to be ordering 20x9 with 15 or 35 offset for the front and 20x11 for the rear with +15. Now on the fronts how much fender work is needed or the front. What would you go with. Now for tires I was thinking 235/40 and 255/40. I'm on coils to.
Any pics would help to.
07-29-11, 12:09 PM
really depends on how low you are. remove the plastic fender liners + liner lip + slight roll for sure.
07-29-11, 12:21 PM
id go +15 on a 225/35 and 265/30/35 rear
roll the fronts
shulda postd pix
07-29-11, 01:09 PM
07-29-11, 01:17 PM
The front should fit really good you could even go 30+ in the front
07-29-11, 01:25 PM
That's what I was thinking for the front.
07-29-11, 01:29 PM
07-29-11, 02:25 PM
+15 more flush..jus a roll should be fine..rears will most likely need work..but all depends how low ur tryna go
07-29-11, 03:39 PM
i co sign with +15 offset ..You'll most likely need a slight pull in the rear or just shaved rear fenders depending on how low your gonna sit. i would go with 225/35/20 for the front 255/35/20 for the rear.
07-29-11, 03:51 PM
I would go with 20x9.5 +15 in the front IMO You'll have better clearance with 225/35/20 tires
07-30-11, 01:28 PM
Master Thread Closer!!
With the front width being 9"...if you go +15...it will stick a bit past the fenders, but will look much better than +35.
With the coilovers, drop it to camber it in...should look very nice.
07-30-11, 02:59 PM
x9 +15 is good, im runnin x9 +1 and its perfect fitment
07-31-11, 03:52 PM
Go with 225/30/20, i have coils alsooo. loooks nice! but i changed it to 235/30/20 now due to many pot holes in the bay area.
08-01-11, 12:37 PM
Are all wheel offsets the same for all wheel manufacturers or do some differ? Cause +15 sounds like it would stick out... but idk.
08-01-11, 12:41 PM
Anthony- your wheel fitment is proper.
