EVAP resistor mod
EVAP resistor mod
Is there any electircal guru or anyone out there that can figure out the correct plug or wire we can add resistor onto? This way we can trick the ecu so it does not throw the P0446 code?
Just like the 02 simulator mods when installing aftermarket headders, you would figure out the correct resistance the pressure sensor sends the ECU for feedback within correct perameters.
This would be of great service to the community and save plenty of headach for people who have emission coming up. I get this code randomly and it has no ill effect on my mileage or how the car runs, would like to get rid of this annoying warning for the EVAP
Thank you
TonyN
Thank you
TonyN
The ecu opens the vsv according to the tank pressure sensor. It's a 3 wire connector, power/ground/signal. So that should be the piece you would need to measure the output when in a functioning evap system to see what range it's operates in. Then you could try to trick the ecu, but the gas tank still needs to vent pressure as it builds. You don't just want to seal it completely, alot of supra guys guy have it vent to atmosphere but some complain about the gas stench around the car and in the garage.
This would be idea because not only does it save money, but in some cases like me where this 0446 code comes up randomly and shuts off randomly, at which it is leading me to believe the VSV is at fault and not the canister itself, it would be worth while.
Is there anyone who could point me to which wire in the engine bay is connected to the wire in on the VSV? I could then look up the wiring diagram and figure out the correct resistant needed.
A simulator will produce the idea condition so that the ECU will never have a reason to give a check engine light in the first place.
from my research the part that goes bad is the one located on the canister under the car, i check the part next to the firewall on under the hood and it looks fine. do you happen to know the part number for the gs300?
Yeah no Cali **** emissioin here LOL.. the only time we ever use the sniffer is on cars that do not have a OBDII port, other than that they hook your car up to the computer and let it idel and make sure there is no check engine lights or codes, so about 30seconds and your good.
Most states just do a plug in test. If the car has OBD-II, they just hook up the OBD scanner machine up to the car. As long as the stock ecu says everything is ok and there are no codes or CEL then the car passes emissions testing. Only time they run a dyno and sniffer is if the car is not OBD-II.
Tony, I think you will have to investigate on your own for this one. I would do some checking, but I'm going to be pretty busy for the next few weeks.
Just wondering, most states if not all(maybe even Cali, Fiend please correct if I'm wrong) allow one monitor not ready. This is because EVAP monitor takes forever to ready up. You should be able to reset the ECU and drive around for a day or so to ready up all of the other monitors. The one EVAP monitor will not be ready, but it should still pass under the 1 allowed not ready rule. If you wait too long, the not ready will turn into a fail code and throw a CEL. At that point it won't pass, so just take it in when all other are ready besides EVAP.
yes, the one i am asking about
Thanks Jeff. And yes you are correct, I will have to put a 50 mile drive cycle before it will be ready for emission testing, the light will stay off for well over 200 miles in some cases, however this is still quite annoying that it does come on and I am not going to do the VSV valve yet. I have the valve just not a whole day or two to take everything off in my garage to get to it and replace it. I rather find the correct feed wire that trigger the light when it reads an incorrect voltage, this would only take a few minutes and save my insanity.
Do you know where I could find the correct diagram for the wires or voltage?
