Weird Weird Weird Foglight Situation
Old 07-11-11, 09:00 PM
D-Boi
D-Boi's Avatar
Default Weird Weird Weird Foglight Situation
I think my car is haunted honestly, or maybe i did a bad deed today but its being weird. One of my ballasts went bad a week ago so i ordered a new one for the fogs.
Here is a breakdown of what happens because im lost as to why its doing this.
1. The bulb/ballast work fine when plugged into the headlight harness.
2. The same bulb/harness do not work when plugged into the foglight harness.
3. So one would think there is no power coming to the foglight harness. However when i plug in a halogen bulb in the foglight harness it works fine.
How the Freak does that even happen, it doesnt make sense to me, but then again my automobile electronic skills are very very novice.
Old 07-11-11, 10:58 PM
Lexus827
Lexus827's Avatar
how many watts are the ballasts 35 or 55
Old 07-11-11, 11:04 PM
D-Boi
D-Boi's Avatar
They are i believe 35 watts. Ok i just checked my ebay listing and yes they are 35w.
Old 07-11-11, 11:40 PM
vipXjunky
vipXjunky's Avatar
check the inner connection of the HID wire to the cars harness. Make sure they both go in, and that the positive is plugged into the right socket. Kind of hard to explain lol. I had the same problem and it was because the connection from the HID to our cars harness
Old 07-12-11, 12:01 AM
D-Boi
D-Boi's Avatar
Totally understand, however if the connector was bad on the fog harness then why would the halogen bulb work fine? Its really awkward, because the whole bulb/ballast works in the headlight harness, while only the halogen works in the fog harness. Maybe shell stop being stubborn tomorrow and ill get it to work.
Old 07-12-11, 11:59 AM
dejavu157
dejavu157's Avatar
on thing u can do. the plug to the power u might have to switch it backwards. sometimes i dont know what but they make it like that. i had to plug and play a lot to get HIDs working. It has always been liek this for me.
Old 07-12-11, 12:09 PM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
multimeter and test light. they are your friends.
Old 07-12-11, 11:47 PM
D-Boi
D-Boi's Avatar
So I figured out the culprit. I had to pretty much reverse the polarity and plug the harness the opposite way on the ballast. How weird is that, the fact that it works when its connected properly on the headlights, and only works when plugged unproperly in the fogs.
Old 07-13-11, 02:10 AM
vipXjunky
vipXjunky's Avatar
haha thats what i meant when i said plugged into the right socket, told u, its hard to explain XD
Old 07-13-11, 09:14 PM
D-Boi
D-Boi's Avatar
^^Thanx man
Old 07-14-11, 12:21 AM
GS4_Fiend
GS4_Fiend's Avatar
Good to know.
Old 07-14-11, 09:33 PM
Timakle
Timakle's Avatar
i had the same issue last weekend i thought it was the ballast or the bulb but i found out it was the wire from the car its was fried when i splitted it to check it a white powder came off the wire i replaced it and now my fog its working fine... i hope this help fix your problem..
Old 07-15-11, 12:50 AM
Clear2Cloz
Clear2Cloz's Avatar
plug it in backwards, the fogs have reverse polarity w/ hid kits...low beams dont.
Old 07-15-11, 12:52 AM
Clear2Cloz
Clear2Cloz's Avatar
guess i should have read the entire thread BEFORE i replied lol. mine are the same way...is it a ddm kit?
aviatorkev
01-14-15 11:28 PM
mday2792
08-05-12 10:01 AM
kgh31386
Lighting
24
07-08-08 10:28 PM
np20412
Lighting
18
06-25-08 08:44 PM
Quick Reply: Weird Weird Weird Foglight Situation
