OIL: High Mileage or Full Synthetic?
I bought my GS400 almost 5 years ago with 106,000 miles on it and since owning now with a 146,000, I used nothing but mobile 1 synthetic, and its been fine, I wouldn't want to use the high mileage stuff I used that in one of my other cars and then switched back to regular oil and seen I quickly had to switch back to the high mileage stuff.
Bumping up an old thread.
I have a 1998 GS400 with 179k miles that has always used conventional oil from the Toyota Dealership. I recently took it to my independent mechanic for some work and he threw in an oil change. When I got the invoice back I noticed that it said "Synthetic Blend." What is a "Synthetic Blend" and how should I be handling my oil changes from here on out? Am I able to go back to conventional? Should I move to Synthetic? Is it recommended to switch to synthetic if I'm at higher mileage? Thanks.
I started to use synthsized oil since 45K now 145 it does have leak here and there not easy to identify, include cover gasket - replaced and oil pan I think.
For old car pls use high mileage oil which soften seals to help reduce leak. if you change oil on time, syn oil won't increase engine life I think. Till now I change oil 8-9K now I want to change it 6month no matter how. I don't drive more than 15K a year.
I do same on my motorcycle but not on my 231k gs300. at firestone they choose the oil for me and its usually high milage. i use regular oil on my goldwing with 142k but no issues on it.
Regular cheap conventional oil
Change every 5k miles, that’s all you need.
We’ve had several cars in our family with over 200k miles that followed the philosophy above - never a problem
