Need help with telescopic wheel
Old 06-30-11, 07:37 AM
jaygill12
jaygill12's Avatar
Default Need help with telescopic wheel
Hey guys i have 98 gs and my wheel was perfectly fine till lastnight, it only moves back and forth and doesnt go up or down. Any ideas what the problem could be?.i tried pressing the button down 9 times and it doesnt seem to go down or up.
guys pls help, the wheel is stuck to high up and its uncomfortable to drive............thanks
Old 06-30-11, 08:16 AM
SlowGS4
SlowGS4's Avatar
This happened to me a while back. Take the steering collumn apart (cover behind steering wheel, and i think the upper part of the foot pannel), whip it down and regrease it. I think i remember pulling the motor out too and regreasing it. It wasnt that bad, probably a 10 minute job. I used lithium grease spray. For mines the old grease started to harden and wouldnt let it move.
Old 06-30-11, 08:55 AM
jaygill12
jaygill12's Avatar
^ could it be anything eale?, im new to lexus and wouldn't mess around with things i dont know!
Old 06-30-11, 12:16 PM
sakataj
sakataj's Avatar
might be better if u wiped it down and not whipped it
no this is MORE than likely it.
welcome to our club man and to keep from cluttering like you reposting this thread we have talked about many times, take a min to look over these. should help you with ALOT of good info
https://www.clublexus.com/forums/gs-...ou-search.html
https://www.clublexus.com/forums/gs-...d-newbies.html
Old 06-30-11, 04:42 PM
pga88
pga88's Avatar
Had the same problem and followed the instructions and mine works great now. Was pretty simple.
Old 06-30-11, 04:50 PM
KenMasters
KenMasters's Avatar
Does the grease job make the wheel motor movement quieter?
Old 07-01-11, 09:10 AM
duster
duster's Avatar
I changed my battery and it immediately fixed the problem. The wheel wouldn't go all the way down before. Sounds weird, I know. Just my experience.
Old 04-08-13, 12:26 PM
jose2006
jose2006's Avatar
JUST REMOVE THE DASH AND REMOVE THE steering column and when I'll put ME NOT FIT IN THE BASE HAS ANYONE KNOW IF THIS SETTING
__________________
Old 04-09-13, 09:21 AM
wbmx1981
wbmx1981's Avatar
Once the steering column shell is off, you need to remove the silver motor, it's tube looking closest to the dash, but on the column. Take it out, clean and regrease it. The copper contacts are more than likely filthy and full of gunk. It's fun and easy.
Old 04-10-13, 07:04 AM
johnno92
johnno92's Avatar
Do you have any pics, or is it all pretty obvious to the casual observer?
Old 04-10-13, 07:52 AM
wbmx1981
wbmx1981's Avatar
It looks something like this. **NOTE** this is just a generic pic. I'm not sure what model Lexus this is from, however they all appear to be similar.
Old 04-10-13, 01:56 PM
marcman804
marcman804's Avatar
I definitely need to regrease the steering wheel. Mine makes this hideous noise sometimes. I was always too much of a punk to take it apart though. I think Ill have at it now though.
Old 04-10-13, 03:27 PM
johnno92
johnno92's Avatar
Thanks for the pic. I guess I know what I'll be doing this weekend. Hopefully the screws come out OK. I have tried removing a window regulator motor on a 1994 Toyota Camry and it was impossible to remove the screws without stripping the heads.
Old 04-10-13, 04:23 PM
MikeFoxx
MikeFoxx's Avatar
Wth is jose2006 saying?
Old 04-10-13, 07:29 PM
jimfbk
jimfbk's Avatar
Quick Reply: Need help with telescopic wheel
