Does my MAF need to be replaced? - GS400
I've been experienceing low idle, cleaned my throttle body, maf, etc. So I'm starting a thread for those that have idle issues, etc. I had my mechanic check out the car and he says it isn't the throttle body itself (he's been dealing with GS/Lex/Toyota solely since forever) but he's on vacation for the next month or so.
So I looked up my GS400 MAF Pinout:
BLK/RED = +B
BLU/RED = VG
GREY = E2G
BROWN = E2
WHT/RED = THA
I did my Ohm test with GND to E2 and POS to THA and I get a 1.743 ohm reading. This is with a Fluke TrueRNS volt/ohm meter. My temps are 74F.
I read that THA-E2 should be between 2.21 - 2.69 omh reading at 68F but thats for the 3UZ-FE (GS430) and THA-E2 should be the same on the 2JZ-GE (GS300), so I will assume the same for the 1UZ-FE GS400.
I didnt do a voltage test connected to my vehicle -- because I figured I'd consult here first.
Any thoughts? - Does my MAF ned to be replaced?
BLK/RED = +B
BLU/RED = VG
GREY = E2G
BROWN = E2
WHT/RED = THA
Its not listed as a transmission mount in alot of auto parts catalogs because the transmission isn't solely held by this mount alone.
I had two jackstands on the frame rails and my 4ton holding the transmission. The hard part was being able to get the holding plate on the transmission up and also push up on the plate to flex the mount enough to thread the bolt in.
BLK/RED = +B
BLU/RED = VG
GREY = E2G
BROWN = E2
WHT/RED = THA
BLK/RED = +B
BLU/RED = VG
GREY = E2G
BROWN = E2
WHT/RED = THA
Yeah mpg isn't a big deal to me. The car needs gas to run so either way I'm filling up.
Can you possibly test out your maf voltage and lmk what it is? Im just gonna buy a new one and program a small circuit board with some electronics to trick the car into thinking the maf into thinking the car is getting "good" air. I'm suprised no one has come up with a fix!!!!
http://lexus.sewellparts.com/accesso...2001/4506.html
im lucky enough to know a friend who has a shop at his house with 2 lifts so i can just lift mine up. i love these l-tuned sides but they so low and wide inside you cant get a jack under them,even a lift has issues with them. i will be doing this the next time im there......
I've been having a series of issues with sourcing a new/refurb MAF.
I purchased two from local auto parts stores and both were bad and refurb'd. I then got one from an online retailer and that one was messed up in shipping. I'm currently fighting with them to get my money back as this was new and it came to me all used and messed up at the mounting clip.
On another note;
I put each MAF in and the car behaved a bit differently at first. My idle while braking went up to around 600rpms vs 400rpms with the old MAF and park idle was up in the 7-800rpm range. then slowly went down back to where it was. Might be my SRT -- but my car idles so quiet at a stop that it works for me.
I got a donor throttle body off of a gs300 and took off the throttle control motor, next I'm going to look at buying a throttle lever assembly ($250). Once I do that, I'm going to remove my throttle body and intake manifold and do my starter, and gaskets and then clean up the throttle body and manifold completely and install the new parts.
I've been working, moving, working on some side projects and havent had much time. I have to redo some suspension work so if you have this issue, stay posted. I will eventually get to it.
My car has 123k miles right now. I've done all the maintenance and also replaced the TPS already.
On another note;
