Door locks acting strange
Old 05-03-11, 06:15 PM
rj4510
rj4510's Avatar
Default Door locks acting strange
A couple of days ago, I noticed my remote wasn't working as it should. It won't set the alarm, or sometimes unlock the doors. I realized it was more a door lock issue. Some lock, others don't, but nothing consistent and the problem seems to switch doors! The only consistent thing is that they don't work properly. Has anyone had this issue? Is there a way to reset the system?
Thanks in advance.
Old 05-03-11, 07:46 PM
porn-adkt
porn-adkt's Avatar
Omg..search
Old 05-03-11, 08:43 PM
KingNasGS4
KingNasGS4's Avatar
its the door lock actuators, a common problem.
I don't think everyone automatically knows about search features.
Old 05-03-11, 08:50 PM
billbillw
billbillw's Avatar
I hadn't even bought my GS yet and I knew about the door lock issue. It was a problem with the very first one I looked at. Came home, searched and viola, this is what I found:
https://www.clublexus.com/forums/gs-...ators-diy.html
Old 05-03-11, 09:00 PM
rj4510
rj4510's Avatar
Originally Posted by ****-adkt
Omg..search
I did and from what I read the actuators were going bad, not working some times and not others. I must have not read the correct posts. So, how do you know which one is the bad one?
Old 05-03-11, 10:32 PM
GS4_Fiend
GS4_Fiend's Avatar
Close all doors and lock it with the key button. Then open the doors and see which one can be opened is the one with the bad actuator.
Old 05-03-11, 10:34 PM
dejavu157
dejavu157's Avatar
yeap yeaps. sucks, everyones lock actuators go bad.
Old 05-03-11, 10:43 PM
fuzzzz
fuzzzz's Avatar
Sigh true, happened to me. Well for OP, its okay. I didn't know about the search option either. People always go mad, so I tend not to ask ..
Old 05-03-11, 11:16 PM
dejavu157
dejavu157's Avatar
^^yeah guy! use the search button, its ur best friend! =P
Old 05-03-11, 11:44 PM
AshburnM3
AshburnM3's Avatar
Change all 4 of them
Old 05-04-11, 12:35 AM
KingNasGS4
KingNasGS4's Avatar
speaking of which. I've always wanted to post, but was afraid to get flamed.
My car since I bought it does this thing in which you cant manually lock the doors (when you try, it just snaps back open) , but you can lock it either the lock button on the door, or the remote. Unlocking manually works normally.
This seems to be the inverse of everyone else's problems
This is on all four of my doors by the way. I was wondering if the previous owner had the actuators changed but it wasnt done properly or something.
anyone actuators ever behave this way? I think it could be affecting my door sensor that senses that the door is open, especially for the driver side.
Sorry to kind of derail your thread.
Old 05-04-11, 05:43 AM
rj4510
rj4510's Avatar
That doesn't quite work. I lock it and one door stays unlocked, then it resets itself, as if I pressed the unlock button. Then I lock it again and the previous door locks and another one is unlocked. It too then reset's to open. I did this sitting in the car and the problems goes from door to door. That's why I posted the question.
I've been on this forum long enough to know how search works. Every other post I read, the actuators were either failing to open, close or both.
The fact that the problem keeps changing doors, makes me think it's a different issue. I'm seeing $$$ adding up pretty quickly now.
Old 05-04-11, 06:58 AM
starfyrels
Account under Legal Action - Banned
starfyrels's Avatar
Gotta love spending money.
I like how everyone assumes its your actuators. Get in your car and manually use the unlock/lock feature inside your car on the drivers door panel. See which doors lock and unlock. There's a Driver door mpx computer and also another one -- or I might be mistaken. It might also just need to be reprogrammed.
In my own personal car, my door locks do somewhat of the same thing. Sometimes they lock, sometimes they dont, sometimes they 'snap back' to unlock from the lock position, etc. I've driven for over a year with this issue and it doesn't seem to bother me. Sometimes I can use the key in the driver door to lock and unlock all of the doors, sometimes not. I thought about replacing all the actuators, but to me I really dont care. The rears are like $70 each and the fronts are cheap since you can get them from the avalon.
What I did was I bypassed my factory alarm and installed my own aftermarket alarm. I dont care if my doors lock because when I'm in the car I can manually lock them and so can passengers, child lock also works.
To me its not a big issue. I'd rather figure out why the steering sucks so much *** in the gs.
Old 05-04-11, 03:54 PM
lexybaby77
lexybaby77's Avatar
Is it all 4 doors, 3 doors, 2 doors? And is it random or there seems to be a pattern?
Old 05-04-11, 07:23 PM
rj4510
rj4510's Avatar
All doors and no pattern that I've seen yet.
Quick Reply: Door locks acting strange
