DIY oil pan gasket?
Old 11-15-12, 09:39 AM
  #31
sakataj
sakataj's Avatar
Originally Posted by neegroy
last time i bottomed out after going through a big dip. no leak but dented the oil pan o.O lets see that DIY fellas!
i posted the link to the DIY, its for adjusting the line pressure but it will show you what you need
Old 03-03-13, 08:41 PM
  #32
ashtray
ashtray's Avatar
http://www.autopartsexpress.com/item...ELPRO&weight=1
BUMP. Do I need to buy this for when I drop the lower oil pan? Or do I just buy the FIPG stuff? Thanks guys.
Old 03-04-13, 05:41 AM
  #33
RPMGraphic
RPMGraphic's Avatar
just the FIPG. dealer doesn't make a gasket & they recommend the FIPG only.
Old 03-04-13, 06:32 AM
  #34
ashtray
ashtray's Avatar
Thank for that sir. Gotta get this done asap I'm leaking tons of oil
Old 03-04-13, 07:09 AM
  #35
RPMGraphic
RPMGraphic's Avatar
make sure you clean of ALL the old FIPG. i had to do mine on my IS. had to lift the motor some to get to the back 6 bolts, not sure about the GS.
Old 03-07-13, 01:30 PM
  #36
ashtray
ashtray's Avatar
What can I substitute FIPG with? Anything at autozone I can get thats really good? I dont mind spending an extra buck at autozone if it saves me money compared to a Toyota/Lexus dealer. Thanks again guys.
Found this on ebay..
http://compare.ebay.com/like/3308756...Types&var=sbar
Looks like a good deal I think. Anyone agree?
Old 03-07-13, 09:29 PM
  #37
sam12345
sam12345's Avatar
You may want to read this
https://www.clublexus.com/forums/ls4...-pan-seal.html
Old 03-08-13, 09:26 AM
  #38
RPMGraphic
RPMGraphic's Avatar
some guys say you can get some good stuff at autozone, but i recommend just getting it from toyota or lexus. i got mine from lexus & it was only $14. worth the piece of mind to me.
Old 03-08-13, 04:36 PM
  #39
ashtray
ashtray's Avatar
Thank you both. Found a deal on Ebay for the good Toyota stuff FIPG.
Old 03-19-13, 10:07 AM
  #40
ganny
ganny's Avatar
Originally Posted by chubz
im going to be doing mine within the next few weeks.if no1 has a diy by then, i will do 1.
Chubz - can you post your DIY, including how to remove the back 6 bolts?
Old 03-19-13, 10:08 AM
  #41
ganny
ganny's Avatar
How to you remove the back 6 bolts of the oil pan? I don't think lifting the engine is a DIY option for me?
Old 04-09-13, 06:24 PM
  #42
Bad99GS400
Bad99GS400's Avatar
i dont know if this is where i should post this but anyone know how to get a new lower oil pan for the 99 gs400? my threads on my drain plug finally went and i know retapping it is only a temporary solution.
Old 05-06-13, 12:35 PM
  #43
ganny
ganny's Avatar
So no one has figured out how to remove the back 6 bolts of the oil pan without lifting the motor? I could easily do this DIY if I has instructions on how to remove the back 6 bolts. Anyone?
Old 10-18-13, 10:33 AM
  #44
youngs3oo
youngs3oo's Avatar
Just recently cracked my lower oil pan too was wondering the same thing. Is there any way to get those bolts out of there without pulling the motor? I tried a flexible ratchet with a swivel but still no luck.
Old 07-12-14, 01:44 PM
  #45
wbmx1981
wbmx1981's Avatar
Anyone that has replaced their oil pan gasket (not transmission pan) please chime in. I developed a leak that appears to be coming from my oil pan gaskets. Valve cover gaskets are new no leaks, cam seal and crank seal are all new, vvti pulley is brand new also so I know these parts listed aren't leaking. Is it best to raise the engine or remove the cross member?
The car is a 99 GS300 232K miles.
Any help is appreciated.
Quick Reply: DIY oil pan gasket?
