thank you guy been a ton of help especially with the pictures . i really like the way it looks under the trunk bar better then the key hole seems like you get better view of your bumper. i went on ebay saw a few cameras how do you guys feel about the one that goes on the license plate ?
I had one of those originally, I personally didnt like the way it looked after I installed it, and the pic quality wasn't good, instead of tree leaves being green they were like pink
since the upper area on the trunk bar has 2 rectangular clear pieces for the license plate light. im guessing the center is hollow also? wonder if that can be cut, extend a clear plastic and hide the camera inside for a clean flushed look.
Originally Posted by 2gs300
i got a cam from a m45 mounted in my trunk key hole
i did this also.......except my tint is so dark i had to use a V-LED tag light to light up the area when i reverse. i didnt use the M45 camera though and ignore the lines in the last pic, its how my camera took a pic of the screen
I have to use the key, so i drilled out the bottom right hole on my license plate and mounted the camera with a rubber gromet behind the plate. I takes alot to drill a hole that big in your car.....but a rubber plug and license plate will cover it up..did something similar with my jeep...
Reason: none
