Need help with fog lights...
Old 03-06-11, 05:14 PM
Mrpoop87
Mrpoop87's Avatar
Default Need help with fog lights...
I bought 2 sets of HID kits for my car: one for low beam and one for the fogs, but the fog lights do not work. The lights are good but they just don't work for the fogs. Is there a specific hid kit just for them?
so I bought yellow xenons in the meantime. But, although they light up, the light doesn't fit in the fog assembly... neither does a different set I got. They are 9006 right??
Old 03-06-11, 05:18 PM
ThomasGS4
ThomasGS4's Avatar
Yes, the fogs are 9006. That's odd that it doesn't fit. Could we have a few pictures?
Old 03-06-11, 09:08 PM
mrcrx28
mrcrx28's Avatar
Yes, fog lights are 9006 bulbs unless you have aftermarket fogs or something. Did you try removing and swapping the rubber O ring around the bulb? Sometimes the one that comes with HID is too thick and won't clear the housing, hence not allowing you to turn and lock bulb.
Old 03-06-11, 09:11 PM
GS4_Fiend
GS4_Fiend's Avatar
What you need to do is spray some WD-40 then try it again. They were made tight.
Old 03-07-11, 12:16 AM
Tank
Tank's Avatar
If you want a different apprach, take the fogs out and losten the three phillips head screws on the metal locking ring, these are behind the rubber O-ring seal, install the bulbs till they lock and retighten the screws.
make sure you have the right aftermarket balasts that connect the the OEM plugs.
Old 03-12-11, 02:03 PM
Mrpoop87
Mrpoop87's Avatar
yea with the other aftermarket bulbs, it's the 0-ring that seems to be too big to fit in there. but with the HIDs', they fit perfectly but just don't work.
Old 03-12-11, 02:27 PM
bigguppy
bigguppy's Avatar
They are 9006 and on the HID try reversing the wire.
Old 03-12-11, 02:48 PM
LexiBlue
LexiBlue's Avatar
If they are not coming on switch the plug going to the ballast around and plug it in and it should come on.
Old 03-12-11, 02:50 PM
gsjason300
gsjason300's Avatar
push harder man.
Old 03-13-11, 12:28 AM
baydriver
baydriver's Avatar
trying switching the wires on the ballast 180 and see if it works
Old 03-13-11, 07:33 AM
OT0814
OT0814's Avatar
If they dont turn on then like everyone says flip the plug going into the ballast around 180 degrees. as far as it not fitting i would probably try some kind of lube lol. or you can lossen the screws on the back. I had a problem getting some bulbs into my high beams and thats what i did
Old 03-21-11, 08:30 AM
Mrpoop87
Mrpoop87's Avatar
Thanks for the advice fellas. I'll try to flip it around once it decides to stop raining over here. As for the other bulbs... would I just be able to swap out the O-ring?
Mrpoop87
Mrpoop87's Avatar
Originally Posted by gsjason300
push harder man.
that's what she said LOL
ALIGN
ES - 6th Gen (2013-2018)
12
02-11-13 02:07 PM
Enigmatic
Lighting
04-25-11 11:52 AM
sirblinks
Lighting
32
09-21-07 07:31 PM
PlayboyzGS
Lighting
02-10-03 09:47 AM
SpectraGS3
06-05-02 11:50 PM
Quick Reply: Need help with fog lights...
