Recomment Key Vendor
Old 10-21-18, 07:54 PM
mefizto
mefizto's Avatar
Default Recomment Key Vendor
Greetings all,
I have purchased a 2005 GS300 with a single master key and I would like to acquire a spare one. I have perused the different fora and if my understanding is correct, I do not have to get a key from a Lexus dealer, but purchase a blank copy, have a local locksmith cut it, and I can re-program the transmitter myself.
I have also perused different vendors, e-bay, ikeyless.com, keylessride.com, amazon.com, but what concerns me is that the prices vary significantly. Thus, I was wondering is someone who went this route could recommend a reliable vendor.
Second, are the following instructions valid:
  • Make sure all doors and windows are now closed.
  • Insert master key into the ignition cylinder and leave it in the OFF position.
  • Cycle the ignition cylinder from ON to OFF five times.
  • OPEN and CLOSE the Driver Side Door 6 times.
  • Remove the Master Key and insert the new Duplicate Key.
  • TURN THE IGNITION CYLINDER ON.
  • The new key will be registered after 60 seconds. The THEFT light on the dashboard will go out, indicating that programming has been completed.
Kindest regards,
M
Old 10-22-18, 09:52 AM
captainva
captainva's Avatar
https://www.clublexus.com/forums/gs-...400-430-a.html
Old 10-22-18, 10:31 AM
mefizto
mefizto's Avatar
Thank you for the procedure. Any recommendation from whom to buy the key?
Kindest regards,
M
Old 10-22-18, 11:21 AM
captainva
captainva's Avatar
Maybe another member can comment on that
Old 10-22-18, 04:14 PM
MRACING
MRACING's Avatar
I purchased a brand new flip key that was precut all I had to do was program it myself. The company is called luxious
Old 10-22-18, 05:23 PM
mefizto
mefizto's Avatar
Hi MRANCING,
thank you for the reply, I have found https://www.luxiousauto.com/, but their web-side is under construction. Do you have a contact? How much did you pay if I may ask?
Kindest regards,
M
Old 10-23-18, 06:06 AM
captainva
captainva's Avatar
There is another thread where their facebook is linked. https://tinyurl.com/y9phdpag
https://www.clublexus.com/forums/gs-2nd-gen-1998-2005/900288-looking-for-remote-without-key.html
mefizto (10-23-18)
Old 10-23-18, 10:06 AM
mefizto
mefizto's Avatar
Hi Muffinizer,
thank you very much,
M
BomBum
06-13-21 05:31 PM
natedahms
05-15-18 02:47 PM
Z07
RX - 1st Gen (1999-2003)
02-06-14 02:44 AM
rashanp102
10-09-12 11:41 AM
horent135
SC- 1st Gen (1992-2000)
06-29-11 09:55 PM
Quick Reply: Recomment Key Vendor
