P1354 help
Old 12-11-10, 09:56 AM
dsouth
dsouth's Avatar
Default P1354 help
I got a 98 gs400 with 175k. cel codes
p1354-vvt malfunction bank 2
p0300,0302,0306,308-misfire codes
p0171-lean code
already replaced oil,spark plugs, and the ocv on the drivers side.
I still have the p1354 code. someone please help.
thx
Old 12-13-10, 09:41 AM
pchuon
pchuon's Avatar
You might need to replace the OCV on the other side. I'm having the same issue. I'm getting bank 1 issues with misfires from 1 3 5 7. Based on forum knowledge that should be on the driver side. I replaced the passenger side OCV on the recommendation from all the threads I've read. Unfortunately, I am having problems figuring out what they mean by left and right side as its all based on perspective. I'm still having cel codes issues. So I am going to replace the driver side tomorrow when I get the part and I'll let you know if it solved the issue.
Old 12-13-10, 11:27 AM
lexus ASM
lexus ASM's Avatar
Your problem is the code you have is for the OCV on the passenger side. Thats bank2 in the V8.
Old 12-13-10, 12:27 PM
ivnnln
ivnnln's Avatar
Could take the picture of OCV on both sides on GS400'98 please? I would like to change on mine as well as for preventive maintenance before it through any codes. I thought the OCV is only on the GS300. Please, take the snap shot. I do not know where it located on mine. Thank so much for doing this.
Old 12-17-10, 09:23 AM
pchuon
pchuon's Avatar
Finally fixed my car!!!! Parkplace was on back order with my OCV. I have a GS400 and I had code P1349 and misfires with Bank 1, cylinder 1 3 5 7, etc. I replaced the passenger side OCV per the dealer! Didn't fix the problem. They told me the WRONG info! I had feeling since the odd numbered cylinder is on the driver side it should have been that side. But of course the dealer knows all, right?!?! After waiting a week for the driver side OCV I replaced that piece and my car immediately was purring like it use to and the check engine lights came off immediatly!
P1349(Bank1)= Driver sided OCV needs replaced
P1354(Bank2)= Passenger side OCV needs replacement
Old 12-17-10, 09:40 PM
ivnnln
ivnnln's Avatar
Good to hear you fixed your problem. Any pictures of the location and the parts, please? I need to replace mine as well. Just don't know where it's located. I am really appreciated if you do me favor by taking a snap shots, pl. Thanks in advance.
schwartzyd
01-24-23 07:55 PM
Nuell101
02-17-18 11:49 AM
Maxx941
06-03-11 06:38 PM
angmedic91
22
10-19-10 04:59 PM
Quick Reply: P1354 help
