GS400 Accessory belt tensioner replacement
Old 12-09-10, 05:06 PM
visildar
visildar's Avatar
Default GS400 Accessory belt tensioner replacement
Hello everyone - I am wondering if anyone has a link to a DIY for replacing my GS400 accessory belt tensioner. It has been squeaking horribly for two weeks now, and I am certain it is the tensioner. Please let me know if you have a link to a DIY or if you know how to remove the old one - I have spent an hour trying to find one - and all I have found are GS300 DIY's....
Thanks,
Vince
Old 07-02-11, 07:50 AM
poohunny
poohunny's Avatar
did anyone ever do a DIY for the GS400? I see one for the GS430, but they look a little different. I assume it is as easy as taking the 3 bolts off the tensioner assembly, removing tensioner assembly, replacing, and reinstall belt?
Old 07-07-12, 06:53 AM
Depfunk
Depfunk's Avatar
Default Same issue here 1998 GS400 need DIY
I went to replace alternator and found Belt tensioner also needed to be replace. I have car apart and need help.....thanks in advance
Old 07-07-12, 08:37 AM
ThomasGS4
ThomasGS4's Avatar
Should've replaced both at the same time since one part goes behind and bolts up with the alternator.
Old 07-18-18, 10:49 AM
socal3
socal3's Avatar
Anyone find a DIY for this I have to replace my idler/tensioner pully also
Old 07-18-18, 04:08 PM
sbagdon
sbagdon's Avatar
Here's a page with a surprisingly large quantity of photos, from every angle:
https://www.oreillyauto.com/detail/b...ensioner&pos=0
Looks like there's (4) bolts holding it on... the question is.. .what has to come out first, to replace it.If you have to go through the alternator, you'll have to pull the belt, pull the power steering pulley, pull the alternator, then you should have room to move things around, once you remove the (4) bolts.
Old 07-23-18, 03:03 AM
Dutchjzs16
Dutchjzs16's Avatar
Hello Vince.
witch part of your belt tensioner is squeaking?
mine was a bad pulley bearring at 207500km.
I only replaced the pulley.
https://shop.febest.eu/catalog/bearings/pulleys.html?brand=LEXUS&model=GS300&year=2000&body=JZS160
Old 07-24-18, 12:10 AM
Dutchjzs16
Dutchjzs16's Avatar
Maybe this will help.
Old 07-25-18, 02:03 PM
lexo98
lexo98's Avatar
Default Pulley
On my GS300 I only replaced the bearing in the pulley. I think they are the same. Do you see a part number on it?
D3V3LOP3R
12-08-15 09:12 PM
mandyfig
06-06-11 08:40 PM
carguy07
11-09-10 09:15 AM
lightwave76
Performance
02-23-06 10:16 AM
TLW
11-18-05 12:36 PM
Quick Reply: GS400 Accessory belt tensioner replacement
