Constant Dash noise like chirping, kissing, squeaking
There is a high frequency (2-3 x second – brief pause – 3-4 x second) noise coming from inside (behind?) my dash.
Weird sound, like kissing, chirping, squeaking kind of thing.
I’m thinking it might be a vacuums system issue but I don’t even know if the second generation GS has a vacuum operated vent / air-con doors etc.
It is loud and annoying as all heck.
I stop the car, turn off the engine, but with the key turned to have the accessories powered up (radio, etc) I hear it.
If I turn everything off the noise stop, then when I turn the key to power the accessories it starts up again.
This is after the car has run a bit – not first thing in the morning, so I’m assuming there IS a vacuum system of sorts.
Anyone have any ideas?
have fun reading,
https://www.clublexus.com/forums/gs-...vo-motors.html
OP u having any issues with your heat/air?
Yeah sort of but
But my noise is inside - and it happens all by itself.
I pull into my garage after driving around - engine running - I can hear it.
I shut down my engine (leave the electrical on) I hear it.
I turn off the ignition completely (remove key) - it stops.
I turn the key one click (electrical stuff on) - I hear it.
When the noise is going on - I try everything I can with the A/C heating / vent controls but nothing makes any difference.
Sigh
Oh *****
I just read the posts about replacing driver side servos.
Merry Christmas !
I HOPE this is NOT my problems.
Is there a link the describes the heating A/C vent system?
How many friggin servos are there?
How do you diagnose which is noisy?
This is not looking good.......
Merry Christmas !
My money is on the servos. How many miles you got? Mine started makings noises all the way back at about 90K, I'm at 180k now, and 2 of my 3 are dead. I'm about to swap all mine out very soon. Winter is coming and I have no heat on the passenger side, and no vent control.....
I think all your questions will be answered in the linked thread, but the short of it is that there are 3 servos, a temp servo for each side, and mode servo. I believe the consensus is, if you're going to replace one, do them all together, to save time and labor. Also, don't replace with used servos.
Sorry about the multiple responses - but I just read the links above (many thanks!)
There was a mention of possible electrical issues - grounding etc.
About the same time that I noticed the noise from my dash - I also noticed my radio having some 'issues'.
The sound changes from stereo to mono and back all by itself - maybe not exactly but speakers come and go.
Are these problems related?
ANY ideas?
Thanks again.
ANY ideas?
Thanks again.
you forgot bout the air recirculation servo
Hi Everyone,
I have the exact same problem as XFEA, I have a gs300 mk2 and there is a high frequency (2-3 x second – brief pause – 3-4 x second) noise coming from inside (behind?) my dash .squeaking... Very loud and annoying.
I stop the car, turn off the engine, but with the key turned to have the accessories powered up (radio, etc) I hear it...
If I turn everything off the noise stop, then when I turn the key to power the accessories it starts up again...
This is after the car has run a bit – not first thing in the morning or very late evening but very loud in the middle of the day.
Unfotunelty, this link doesn't work for me, I don't know if it has been taken down, does anyone have any other advice/reading?
