Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Sign in using an external account
Register Forgot Password?
Wheel width/offset/size and tire fitment Q&A thread
Thread Tools Search this Thread Display Modes
Old 11-07-10, 09:58 AM   #16
AMSMIKE
Trader Score: (40)
AMSMIKE's Avatar
Quote:
Originally Posted by Neo View Post
The specs are pretty conservative so I don't think there will be any fender rub issues. Depending on the drop specs, the only rub I might see happen (because you are going with the fat setup) is the top of the fender liner on big dips.
Thanks for the info
Stance coilovers. Just lowered enough to eliminate the wheel well gap.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
__________________
GS600
AMSMIKE is offline   Reply With Quote
Old 02-23-11, 04:25 PM   #17
Hypebeast
Trader Score: (1)
Thoughts on this setup? Are these pretty conservative fitments? Am I going to be rolling sunken battleships?
19x8.5 +40 front
19x9.5 +38 rear
Click the image to open in full size.
Hypebeast is offline   Reply With Quote
Old 02-23-11, 04:31 PM   #18
Anthony
Trader Score: (4)
Anthony's Avatar
pretty sunk..easy fit
Anthony is offline   Reply With Quote
Old 02-23-11, 04:33 PM   #19
Hypebeast
Trader Score: (1)
I guess the bright side is I can dump it with minimal fender work. What tire size would you suggest ?
Old 02-23-11, 05:55 PM   #20
YaKuZa_GS
Trader Score: (13)
YaKuZa_GS's Avatar
justin.wallace.37201 @j_wallace
Unfortunately OP this thread is useless. No matter how many threads are out there, there will be some jackass who won't/can't search for the answer and will make a new thread. sad but true
AMSMIKE that size is almost 1" taller than the OEM setup. You got the widths right but sidewall profile wrong.
245/35R19
275/30R19
This is proper. If you go with your tire setup not only is it 1" taller when you turn you most likely will rub esprecially if you are lowered.
overall diameter of the OEM 16's is onlt 26.16 and the OEM 17's is 25.33 so you should stay between there
Here's a good quick reference
http://www.tirerack.com/tires/Option...0&autoModClar=
__________________
YaKuZa_GS is offline   Reply With Quote
Old 02-23-11, 06:17 PM   #21
entryspeed
Trader Score: (3)
entryspeed's Avatar
For those looking for fat(er) tire set up mine is as follows with only triming the rear inner fender lip to fit.
19x8.5 +34 F w/either 235 or 245/35/19 no mod at all and rim is fairly flush +30 ideal offset I think in front (my opinion with out stretch).
19x10 +30/28 w/285 or 295/30/19 Only have to trim the lip off the inner fender and the 295's look really sick if you like the wide stance in the back.
My .02 some will say different but I have had this on my car and I tucked the rear tire with out rubbing. GL all
__________________
95 SC300 BLK 5spd sold
2000 GS400 SLV
1999 GS400 BLK
entryspeed is offline   Reply With Quote
Old 02-23-11, 07:59 PM   #22
phillygs3
Trader Score: (5)
phillygs3's Avatar
Feel free to pm me with questions fellas and I can help out, when you pm me please leave what susspension and how much camber your willing to run. and if your willing to shave and roll the fenders
__________________
Liberty VIP
phillygs3 is offline   Reply With Quote
Old 02-24-11, 07:57 AM   #23
Bippu147
Trader Score: (9)
Bippu147's Avatar
poor_form Fistn LolzDeep
Send a message via AIM to Bippu147
on my winter setup right now i'm running 19x9/10 +22 all around, 225/40 Blizzaks all around. Slight roll all around. Would be a great setup for someone looking to get flush but not super crazy.
Although I would run a 255/35 on the rear instead of a 225/40.
Only reason i'm running that same tire size all around is because the tires were on closeout for $125each haha....dirt cheap for those 19" winter tires.
__________________
Quote:
Originally Posted by speedaddic View Post
have you considered Vossen wheels? The look and feel of ultimate luxury with the pricing of Walmart?
HKS Pro Tuner / Apexi Power Exel Certified Tuner / AEM Factory Trained EMS & Infinity Tuner / Haltech Certified
Proud to be a "hater" that defends Authenticity
Bippu147 is offline   Reply With Quote
Old 02-24-11, 06:51 PM   #24
Hypebeast
Trader Score: (1)
Quote:
Originally Posted by Hypebeast View Post
19x8.5 +40 front
19x9.5 +38 rear
Trying to price tires right now for 19 vs 20....what size should I run for this setup. Probably going to lower on coilovers, don't want to run stretch, keep it with in the factory diameter if possible.
What about the tire sizes for a 20x8.5 f, 20x9.5 r (+35 & +40) ??
Old 02-24-11, 08:09 PM   #25
AKS14
Trader Score: (0)
I got a set of
19x9 +24
19x10 +24
Thinking of running like a 225/40 or 235/35 up front and then a 235/40 or 245/35 in the rear, or something along those sizes.
Im planning on shaving the rear fender and rolling the front.. Just wondering what you guys think about it. From what I've seen/read looks like it should fit pretty easily without too aggressive of an alignment.
AKS14 is offline   Reply With Quote
Old 02-24-11, 09:43 PM   #26
Bippu147
Trader Score: (9)
Bippu147's Avatar
Run 225/40 up front, 245/35 in the back. you'll still need to roll fenders
__________________
Old 02-24-11, 10:07 PM   #27
GS4_Fiend
Trader Score: (22)
GS4_Fiend's Avatar
Here's a great website will illustrations.
http://www.willtheyfit.com/index.php...&Submit=Submit
GS4_Fiend is offline   Reply With Quote
Old 02-24-11, 10:55 PM   #28
AKS14
Trader Score: (0)
Quote:
What sort of camber do you run front and rear? Just curious as your current wheels/tires are pretty close to what I'll be running.
Old 02-24-11, 11:45 PM   #29
revel
Trader Score: (0)
otakurevel
are those SSR Koenigs? didnt realize they came in a 19". such sexy wheels. so classic and timeless.
revel is offline   Reply With Quote
Old 02-25-11, 05:04 AM   #30
lkapimp216
Trader Score: (2)
lkapimp216's Avatar
you should run a 225/35 and 235/35 on a 19 and you should be right in factory spec. The stretch will be slightly more on the rear so the diameter should be same front and back, or pretty damn close
Quote:
Originally Posted by AKS14 View Post
I got a set of
19x9 +24
19x10 +24
lkapimp216 is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Question about wheel fitment RichFlair IS F 9 05-30-14 09:05 AM
Wheels for IS300??? EddieFLO Suspension and Brakes 2 01-31-14 09:18 PM
Another wheel fitment question... 2S13S14LS LS430 2 08-14-13 10:59 AM
Wheel/ Tire fitment question. (Can't find answer) lol The Tire Rack's Tires, Wheels & Brakes Forum 5 06-25-13 06:43 AM
Wheel fitment questions x3kenster GS - Third Generation 5 03-03-13 08:51 PM
Tags
19x85, 2853519, 2nd, fit, fitment, generation, gs, inch, lexus, put, rim, size, tire, tires, wheel
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
