Wheel width/offset/size and tire fitment Q&A thread
Old 01-18-12, 10:07 PM
  #211
Lexustrung
Lexustrung's Avatar
19x9.5 + 22
19x11 +25
planning to run tire sizes 225/35/19 and 245/35/19
what kind of fender mods would be needed?
roll in front and shave in rear?
going to drop on stance coils, currently on tein cs v2
Old 01-18-12, 10:19 PM
  #212
Bippu147
Bippu147's Avatar
Roll all around. That'll fit nicely
  #213
Anthony
Anthony's Avatar
roll front..shave rear and a decent amount of camber just a couple of degrees.. 11 +25 is only 3mm more aggressive than the 10.5 +22
Old 01-21-12, 07:46 AM
  #214
midship909
midship909's Avatar
Just want to make sure before I buy will 19x9.5 +18 and 19x10.5 -1 fit? I know I need to cut shave the rear but will I need to pull?
Old 01-22-12, 02:51 PM
  #215
HrdPrkDGS4
HrdPrkDGS4's Avatar
Looking into xxr 526 20x9 +15 up front and 20x11 +15 in the rear is what kind of work am I looking at to make at least the tires tuck with a good stretch ? Roll up front shave and pull in the rear?
Old 01-23-12, 06:15 PM
  #216
SELFMade
SELFMade's Avatar
Hey guys, will 19x9.5 +22 all around be flush dropped on Megan EZs? I'm assuming there wont be any rolling or pulling required.
asiszn (11-15-22)
Old 01-23-12, 07:18 PM
  #217
5t341th
5t341th's Avatar
should be cool with a mild pull, or just more camber
im 9.5+5 fronts which fit fine
my rear 10.5+0
Old 01-27-12, 10:22 AM
  #218
midship909
midship909's Avatar
my rear 10.5+0
Thanks for the help. How much camber are you running
Old 01-27-12, 10:45 AM
  #219
palapinga
palapinga's Avatar
sup guys doing some research wanted to know if any one has put is-f stocks what tires you used and do you have your fenders rolled?
Old 02-03-12, 02:55 PM
  #220
Sickpainte
Sickpainte's Avatar
I'm am currently dropped on d2 coil overs and just ordered some varrstoen 2.2.2 wheels 19x9.5 in the front and 19x10.5 in the rear with +22 all the way around, what will be the best tire combo for a daily driver with minimal rolling or shaving.
Old 02-03-12, 03:25 PM
  #221
SELFMade
SELFMade's Avatar
How is the ride in oppose to stock on those D2s?
Old 02-03-12, 03:39 PM
  #222
Sickpainte
Sickpainte's Avatar
On huge drop offs like bad overpasses it's a little soft feeling kinda lime a floating caddi but other vise the ride is awesome but I'm also slammed, I'm very impressed
Old 02-03-12, 03:54 PM
  #223
808_GS400
808_GS400's Avatar
a 225/35 front and 245/35 rear should be nice
Old 02-03-12, 04:24 PM
  #224
Sickpainte
Sickpainte's Avatar
Will a 235 work better in the rear or just stick with 245
Old 02-03-12, 05:03 PM
  #225
Rob Daddy
Rob Daddy's Avatar
I have a question about tire fitment.
I have a set of 20x10.5 +25 & 20x9.5 +25
Lowered on TEIN CS what kind of fender mods & what tire size is recommended for sometimes spirited driving?
Quick Reply: Wheel width/offset/size and tire fitment Q&A thread
