Good source for 12v ignition on?
the amp wire goes direct to battery ? right? u can make a split off the wire and put in a relay that is controlled by the signal wire that goes to the amp.
relay is the best way to go about it for anything electrical thats extra. not good to ever split off a known ignition wire that powers something else..
ok i understand what u saying,,,, for an air compressor i would run a whole new line direct from the battery .... ignition on for signal only u can split off of anywhere ...hmmmmm?? ohhh there is the fuel pump control unit somewhere around there the driver side quarter panel ....up in there somewhere ,,,,,that gets ignition on power
iModerate
I would run a wire from the front passenger side of the vehicle to the rear. Tap into the seat heaters or the cigarette lighter and ad a fuse. Select a source that will not shut your whole car down if something goes wrong. Tapping into a vital component is probably not the best choice.
maxx430
08-23-12 10:46 PM
P Rock
05-04-07 05:42 PM
