Audio possibilities?
Old 09-06-10, 08:34 PM
TLcoats
TLcoats's Avatar
Default Audio possibilities?
I've decided to keep my car after thinking about all the factors involved. I've done some searching about audio possibilities for our cars. But i was wondering what i could do with my audio system since i have OEM navigation and i can't really install a headunit.
I know 4" speakers fit in the stock location but theres a way to make an adapter out of MDF to fit 6"x9"? So i was wondering what brand-model you guys think would sound best. Also as far as amp and sub setup. I really don't know much about audio, i'm wanting to do 6"x9" all the way around and an amp and 10" in the trunk. What brand's/ types would be best? Thanks again audio gurus i'm sure this thread could help us other trolls in the audio world.
Old 09-06-10, 10:13 PM
Baliztik
Baliztik's Avatar
There's an audio subforum. I would search there first.
Old 09-06-10, 10:18 PM
Alexusoftime
Alexusoftime's Avatar
i think 6x9 are way to big...for the doors i would suggest 5 1/4 components is the best way to go
Old 09-06-10, 10:37 PM
Frankdorn
Frankdorn's Avatar
I'd definitely check the audio forum -- TONS of info there. Most go with 6-1/2" component sets for the best sound. 6x9s aren't that great. As far as brands, it's all in how much you want to spend. Wanna blow a grand on front speakers? You have a lot of options.
Old 09-06-10, 11:31 PM
TLcoats
TLcoats's Avatar
Thanks guys. Yea i men't 6 1/2" haha. 6x9 would be huge in our lexus doors! I've looked through the audio sub forum but there isnt much info on GS4's with oem navigation. So my question is would i be able to get new door speakers, an amp and a sub and be able to run it off the stock navi head unit? Is $700 a reasonable price range? Thanks again guys.
Old 09-07-10, 08:23 AM
Frankdorn
Frankdorn's Avatar
Yup, all will work. Door speakers will go right in after you make a 1/4" or 1/2" adapter template for the doors (take the existing speaker boxes out and take the screws out to use 1/2 the box as an outline). Cut your circle in the middles and bolt down to the OEM points where the OEM boxes were bolted in.
The amp and sub will work, too, but you'll need a "line output converter", or "LOC". A search'll have plenty of info, but basically its a $20 part you use to pull off a signal off a speaker wire to get a signal to your amp. Its better to put the sub in a box than a free-air in the hole, although a free-air does work. Just not as tight/punchy/strong as in a box.
$700 will work if you use the classifieds/Craigslist/ebay. Remember your speakers are like your brakes: the fronts do 70% of the work, so put money in those. You could leave the rears stock.
$150 front speakers
$100 amp
$100 sub
$50 LOC/wiring
$remainder savings account.
If you think I'm crazy, I'll have you know mine was cheaper.
Old 09-07-10, 12:26 PM
TLcoats
TLcoats's Avatar
$150 front speakers
$100 amp
$100 sub
$50 LOC/wiring
Once again Frank, You DA' man! Thanks for the info buddy i'll start piecing together a nice little sound system. What do you think about dynamat? I know the door kit is only $150. What do you think about the stuff? Thanks again. I'll post pics of my build!
Old 09-07-10, 12:29 PM
sam430
sam430's Avatar
or you can buy my ms-8 for 700 bux and start from there
Old 09-07-10, 01:12 PM
TLcoats
TLcoats's Avatar
Just snooping around craigslist i found some things.
Also, should i be running a seperate amp for the speakers and then another amp for the sub? Or could i just run one for the whole system?
Amp?
http://www.sonicelectronix.com/item_...08ZX350.4.html
Sub?
http://www.sonicelectronix.com/item_...se+SW8010.html
Front Speakers (6-1/2")
http://www.crutchfield.com/p_500SPS6...ml?tp=95&avf=N
Wire (What Gauge?)
http://www.crutchfield.com/p_211UCT1...re.html?tp=978
Dynamat Xtreme Door kit
http://www.crutchfield.com/p_1541043...t.html?tp=2803
Integration Kit??
http://www.sonicelectronix.com/item_...10ZXSUM8-.html
Sub Box
http://www.sonicelectronix.com/item_...ute+SS-10.html
Does this look about right? I really dont know much about car audio but im starting to learn. Any input would be appreciated!
Old 09-07-10, 01:27 PM
sam430
sam430's Avatar
there is an eclipse 10" single vc 4ohm 700wrms eclipse sub for 99 bux at sonic elecronic.
Old 09-07-10, 01:42 PM
TLcoats
TLcoats's Avatar
Wow that is a great idea. Thanks sam, I just might have to buy that and a box right now!
Old 09-07-10, 03:14 PM
Ogvenom
Ogvenom's Avatar
depends on how clean u want it to sound i spend that much just on a pair of hertz 163 6.5 and a pair of hertz 5 1/4
Old 09-07-10, 03:17 PM
Ogvenom
Ogvenom's Avatar
Amp?
Sub?
Wire (What Gauge?)
Integration Kit??
Sub Box
still missing a 2 ch amp for the 10" woofer ur going to want an amp that does atleast 1000 rms @ 1 ohm
Old 09-07-10, 05:07 PM
TLcoats
TLcoats's Avatar
Can't i just run one 4 ch amp? Two ch for the front two speakers then i can run the sub off of it too?
Old 09-07-10, 07:50 PM
speedaddic
speedaddic's Avatar
Eclipse is out of the car audio business. that's why the subs are so cheap. Once they blow...they blow...
Quick Reply: Audio possibilities?
