parking lights not working 2002 GS300
Old 08-20-10, 07:02 PM
komar
komar's Avatar
Default parking lights not working 2002 GS300
Hello,
My brother just got a 02 GS300, but it didn't come with a owner's manual...
I need to know where the fuse is for the tail lamps. There is 0 exterior lighting with the switch in "p" mode. Head lights work fine in Low and High when activated by switch. DRL works fine too. The rear bulbs tested good, brake lights illuminate when peddle depressed, but no parking lights from front or rear.
I've looked in the passenger kick panel, under the hood near battery, near the master cylinder with no luck. where else is there a small fuse panel ???
Thanks for the help!
Kareem
Old 08-20-10, 07:59 PM
Mr Jokster
Mr Jokster's Avatar
Theres another one right next to the parking brake on the driver side.
Old 08-20-10, 08:58 PM
komar
komar's Avatar
thank you. will check there in the morning
Old 07-13-11, 02:07 PM
TonyN
TonyN's Avatar
Bumping an old thread.
I have a 00 GS3. Replaced the parking bulb (the one in the high beam housing) it will not turn on.. I tried looking for fuses but do not see any that say parking light. any idea?
Old 07-13-11, 02:23 PM
Debonair
iModerate
Debonair's Avatar
I did a quick search and found this.
https://www.clublexus.com/forums/gs-...id-i-blow.html
Originally Posted by Debonair
I just took a look at the diagrams and it appears both the License plate lights and the parking lights hook up to the 10A "TAIL" fuse in the left kick panel. If this fuse is the issue your front side markers should be dead also as they go to that fuse as well.
Old 07-13-11, 04:06 PM
TonyN
TonyN's Avatar
Thanks but I think I jumped the gun. Replace the bulb and well yeah. The "new" bulb was broken also lol.. tried LED and they work. Thanks for the response.
Old 02-10-15, 11:48 AM
dncs4e
dncs4e's Avatar
how do you replace the parking light bulbs do you need to actually remove the whole bumper
AlanVR
RX - 1st Gen (1999-2003)
08-08-14 09:18 AM
jaydmmanny
10-16-12 10:05 PM
NimaM
09-30-12 09:55 AM
kayexalate
11-16-08 02:46 PM
stvIS250
09-21-08 08:36 AM
Quick Reply: parking lights not working 2002 GS300
