98 GS400 battery light and vcs light on
Old 08-20-10, 08:47 AM
dglange
dglange's Avatar
Default 98 GS400 battery light and vcs light on
I just replaced the battery and alternator and now my battey, vcs /vcs off light is on. I had my alternator rebuilt by a repradable alternator/starter rebuilder. after I finished installing and started my GS and checked to see if it was charging ok. I was charging at 14.5 volts. When I took it for a test drive the battery light came on and then went off. I noticed when I accelerated it came on and when i came to a stop it would turn off. After 5 min of driving the VCS / VCS off light comes on and stays on. Now both lights are on. however the battery light still goes on and off.
Old 08-20-10, 08:57 AM
Debonair
iModerate
Debonair's Avatar
Did you get your alternator built to have a higher output then normal?
Standard voltage is 13.2-14.8 V. When you accelerate the voltage may be getting higher then the normal 14.8 V cap and therefore setting off the Battery light. When you slow down the voltage is prob dropping to 14.5 which is in spec so the light goes out.
Old 08-20-10, 09:42 AM
dglange
dglange's Avatar
No, I just had them rebuild to factory specs... is the causing the vsc light come on? I guess it possible they beefed it up a little.
Old 08-20-10, 09:59 AM
kingkirby
kingkirby's Avatar
try resetting your ecu. its in the fuse box by the battery.
Old 08-20-10, 10:01 AM
dglange
dglange's Avatar
I unpluged the battery for 5 min... will that work or do i need to unplug the ecu?
Old 08-20-10, 10:04 AM
kingkirby
kingkirby's Avatar
try waiting longer than 5. maybe 15? i think i had a similar problem way back. and i took out the ecu fuse for a bi and it went away.
Old 08-20-10, 11:19 AM
dglange
dglange's Avatar
i reset the ecu and still same issue... if the alternator is over powered will that cause the vsc light to come on?
Old 08-21-10, 11:37 AM
dglange
dglange's Avatar
Great news... I took the alternator back to rebuild people and the checked it out and it had a defective regulator. They replaced it. I reinstalled the alternator and it works perfectly. Thank you all for your input!!!!
Old 08-21-10, 02:42 PM
jspecdan
jspecdan's Avatar
good to know you got it fixed
pkirwin
02-14-16 02:13 PM
stvnmj
SC- 1st Gen (1992-2000)
15
01-30-12 07:32 PM
Ace2jz
Performance & Maintenance
01-29-11 10:28 PM
lbq
16
03-09-10 12:01 PM
jewelerz
Maintenance
09-12-03 10:14 AM
Quick Reply: 98 GS400 battery light and vcs light on
