Go Back   Club Lexus Forums > Lexus Model Forums > GS Models > GS - Second Generation
Sign in using an external account
Register Forgot Password?
removing the neutral safety switch. Anyone?
Thread Tools Search this Thread Display Modes
Old 08-09-10, 11:16 PM   #1
tamtanium
Trader Score: (0)
Default removing the neutral safety switch. Anyone?
I'm having a problem after i got my car back from a body shop. They replaced the driver side fender and doors for me. Now i can't get out of Park unless i press down the switch. Also the gears indicator light on the gauge cluster is not working.
- I have checked all of my brake lights and they are all in working order.
- I checked the STOP fuse and it's good. Checked the rest of the fuses and everything is good.
- I also exchanged a brake switch with another car. Didn't solve the problem.
The only thing left i can think of right now is the neutral safety switch. But I can't take it out completely. It's stuck because there's not enough room to take it out.
Have anyone done removing the neutral safety switch on the transmission for the GS yet? I managed to removed the two bolts but now i can't completely take it out because it's hitting against my car frame. Give me some tips if you have done it
Is there a way to test the part to know that it's the problem?
This is a picture i found of the part that's hitting against the frame
Click the image to open in full size.
Thank you!
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
tamtanium is offline   Reply With Quote
Old 08-09-10, 11:50 PM   #2
excluesive
Trader Score: (10)
what does said part do?
__________________
This is an internet forum, reading comprehension is key.
excluesive is offline   Reply With Quote
Old 08-09-10, 11:55 PM   #3
tamtanium
Trader Score: (0)
Quote:
Recently i can't put my car into any gears. It's stuck on Park unless i push down the switch and my gears indicator light on the gauge cluster is not displaying =(
I read on the forums and the neutral switch seem to be the problem causing all of that.
Old 08-10-10, 12:00 AM   #4
excluesive
Trader Score: (10)
have you checked the fuse panel by your left foot. I had this problem and it was a fuse that is related to the brake lights.
__________________
Old 08-10-10, 12:24 AM   #5
tamtanium
Trader Score: (0)
I checked all of the small fuses on the bottom left panel. Can you give me some more details on which fuses?
Old 08-10-10, 06:27 AM   #6
Infamous 1
Trader Score: (20)
the "stop" fuse.
__________________
'04 E55 AMG
NELOC
Infamous 1 is offline   Reply With Quote
Old 08-10-10, 11:08 AM   #7
AsGs300
Trader Score: (0)
AsGs300's Avatar
Send a message via MSN to AsGs300
Quote:
Originally Posted by Infamous 1 View Post
the "stop" fuse.
dude before you went tearing your car apart, shoulda searched some threads, there have been a few members on here that have been a victim of this! all it was , was a $0.25 fuse
__________________
AsGs300 is offline   Reply With Quote
Old 08-11-10, 02:03 PM   #8
LamboGS3
Trader Score: (0)
theres fuses under your hood, left kick panel and right kick panel. check everyone of those fuses..
LamboGS3 is offline   Reply With Quote
Old 08-11-10, 06:47 PM   #9
tamtanium
Trader Score: (0)
Quote:
I have checked the STOP fuse and the passenger side under the hood side. Are there fuses on the right side? I thought they're just relays
I'm seriously running out of idea. I got the car back from the body shop because they were installing a new fender and door for me. I'm assuming they short or blew a fuses while doing that. Are there anything under the driver side fender that can cause this problem?
Old 08-12-10, 10:44 AM   #10
JiBBeL
Trader Score: (2)
Are you visually inspecting the fuses or using a multimeter? After having some work done on my car recently, a bunch of random fuses were blown. 9/10 of em were visibly blown, but one fuse was a sneaky lil Sh$5*...
__________________
2008 Lexus RX350
2007 Audi S8
JiBBeL is offline   Reply With Quote
Old 08-12-10, 03:38 PM   #11
tamtanium
Trader Score: (0)
Quote:
I checked with this fuse tester and a multimeter. I know it gotta be a fuse or a short somewhere. Everything was running good until the body shop touched my car.
I'm going to attempt to check the passenger side kick panel today and see.
Old 02-16-14, 02:27 PM   #12
Gs400blk
Trader Score: (0)
Did you ever figure it out I'm having the same problem I checked all my fuse and I already tried changing the brake light sensor switch....
Gs400blk is offline   Reply With Quote
Old 12-29-14, 09:11 PM   #13
donovandon
Trader Score: (0)
I am also having the same problem where i cant shift gears without pushing the button near the shift ****. any advice?
donovandon is offline   Reply With Quote
Old 12-29-14, 10:11 PM   #14
justim
Trader Score: (0)
Check your brake lights. The car will not shift out of park unless the brake pedal is pressed, if the brake switch is broken or stuck you cant shift (and your lights wont work either).
I drove around for a week in my old ES300 before someone told me none of my brake lights worked. I had to use the release button to shift from park. Turns out it was the switch on the pedal.
justim is offline   Reply With Quote
Old 01-02-15, 04:29 PM   #15
donovandon
Trader Score: (0)
where is the switch on the pedal and do you have the name of that switch by any chance?
Similar Threads
Thread Thread Starter Forum Replies Last Post
Starting problem GS400AZ GS - Second Generation 3 04-14-15 08:02 PM
"P" and "N" lights controlled by neutral switch? R7000 LS400 1 05-16-14 07:02 AM
02 ES300 No start Electrical Nightmare Tobys3381 ES300 and ES330 6 07-15-13 11:30 AM
Before replacing the starter please check this!Park/Neutral safety switch adjustment etj1085 LS400 7 02-24-13 10:59 PM
embarrassing worker GS - Third Generation 5 09-14-12 01:34 PM
Tags
02, 2007, 350, cant, es, es300, fuse, lexus, neutral, nutural, park, position, remove, safety, switch
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
