gs400 and tundra oil filter same? JeffTsai K&n filter
Old 07-26-10, 12:50 PM
toy4life86
toy4life86's Avatar
Default gs400 and tundra oil filter same? JeffTsai K&n filter
hey whats going on i was looking online and was trying to find part numbers for the 2
this is the one i got for the lexus gs400
90915 YZZD3 OE/90915YZZD3OE
and this is the one i got for the tundra
90915-YZZB5
I wanted to use the K&n hp-2009 like jeff posted would it work
Im assuming so last time i got the lexus and the tundra filter from the dealer I think it was the same
just wanted someone to chime in before i go ahead and order
Old 07-26-10, 02:29 PM
alexulan
alexulan's Avatar
Correct they are the same.
Do a search there are some very in depth threads re best filter
Old 07-26-10, 02:59 PM
toy4life86
toy4life86's Avatar
i know i read the toyota japan filters etc WIX
I know they are good and better I change my oil at 3000 miles
and have had cars just using crappy Fram filters still fine
I just wanted to do a upgrade since I am purchasing online but Id be fine with anything
I am going to go with the K&N its a good price and is bigger its more than the USDM toyota filter but I think those USDM filter for the gs400 is very small so i wanted to upgrade from that
Old 07-26-10, 05:30 PM
BCP43002
BCP43002's Avatar
What I think is weird is my 430 and V-6 Highlander have the same Pureone filter also.
Old 07-26-10, 06:48 PM
toy4life86
toy4life86's Avatar
i think alot of the cars trucks share the same filters
in the toyota family i think there may be only a handful of different sizes
Old 07-27-10, 05:18 AM
97JZA80
97JZA80's Avatar
I use the YZZD3 on every car in my signature except the alltrac....supra technically has a different one but I run the YZZD3 in it too.
Old 07-27-10, 09:11 AM
toy4life86
toy4life86's Avatar
what happend to your tundra
Old 07-27-10, 10:01 AM
GS_Louis
GS_Louis's Avatar
Filters are interchangeable. Tacoma's, Tundra's, basically all lexus', some older camry's, and dodge neon's use the same filter. I currently work at jiffy lube and deal with this everyday.
Old 07-27-10, 10:05 AM
3UZFTE
3UZFTE's Avatar
Yeah, pretty much any filter will work, like it was stated above, I pretty much use D3 on everything minus Corollas and Camrys. The D3 filter is an awesome filter, and it is one of the bigger screw-on ones that Toyota offers. I really don't think it's the size of the oil filter that matters, I think what you should be worried about is the micron rating of the filter screens and oil pressure relief valve specs, and quality of o-ring used might be a better indication of a better filter to use. Even if you go with a massive oil filter, it is likely it is only going to hold an extra half qt., which isn't really enough capacity to be considered a a major benefit... or is my theory just might be off?
rd400racer
07-10-19 03:44 AM
Cadd
Maintenance
12
05-01-04 11:55 PM
teke52
Maintenance
03-29-04 09:13 AM
engin_ear
Maintenance
04-29-03 07:32 AM
Quick Reply: gs400 and tundra oil filter same? JeffTsai K&n filter
