Catalytic Converter on the rocks
Old 06-04-10, 02:57 PM
CPMD
CPMD's Avatar
Originally Posted by Aristo8
I was told by my stealership that I needed to change both of my cats.. 1200 each when my Check Engine light came on.. I went home jacked the car up.. got under it and felt air pushing thru the bolts on the cat.. I opended it up and the gasket was in pieces.. went back to Lexus, bought the 2 gaskets for $12 each.. put them in Check Engine light is gone.. car is quieter and I havent had any problems since.. check that..
That's freakin awesome...good for you man . $24 instead of $2400...ha ha.
Old 06-04-10, 03:33 PM
dealer374
dealer374's Avatar
Originally Posted by matt21484
I dont' mean to hijack, but I'm going to...I've been hearing what sounds like the rattle inside of a spray paint canister at times from under my car (01 GS300), is that indictive of a cat going bad. No CEL lights (or rotten egg smell) yet, just curious. If that isn't enough info, let me know and I can do some more research on my own. I guess I'm just curious as to what other symptoms lead up to a "bad" cat.
(Not to contiue the jacking *no homo*) Check your heat shield. Mine does the same thing I found a clamp that rotted off and the shield itself started to rot.
Old 06-07-10, 04:18 PM
jcastaneda
jcastaneda's Avatar
Well I check for air leaks but didn't find any. It's been several days and a lot of driving and the engine light has not on again.
The mechanic also told me to run regular gas through the system that it may clear it up. I do know it did clear up the problem with my tach almost bottoming out in the morning. I was running premiem and the mechanic said it may not be atomizing the gas the correct way which could cause both of these problems.
Hopefully I killed 2 birds with 1 stone...saving $$ at the pump and no CEL!!
Old 06-08-10, 12:14 AM
YviE
YviE's Avatar
That sure would be cool. I hope the cel won't come back.
Old 07-08-10, 11:56 AM
Rich23
Rich23's Avatar
Okay guys, time to chime in... Sorry to bite off you here but I may be in the same boat too...
For the guys who bought the aftermarket cats, what brand/partnumber/price did you pay... I know someone said that they paid 1/4 of dealer cat but a figure will help.
Also, what is the length of the cat, is it 13.25"? I know the inlet/outlet is 2 1/4"...
It is for a GS400
thanks in advance...
Old 07-11-10, 03:30 AM
TheBean
TheBean's Avatar
Im having this same problem and its pissing me off. Any help would be greatly appreciated.
Old 07-11-10, 05:59 PM
Rich23
Rich23's Avatar
Nobody with a response???
Old 07-11-10, 09:09 PM
miaristo
miaristo's Avatar
I just hit the 101,000 miles and the PO430 CEL came on.( i check all the above) i hate that light on my face already. Any one have aftermarket headers on a 02 GS300?
Old 07-11-10, 10:13 PM
YviE
YviE's Avatar
Where is the sound coming from? Front or back?
In the front, it could be the ceramic element in the cat that's coming loose. In the middle or back, it could be a part in a muffler/resonator coming loose (perforated tube or something).
You should go under your car and start knocking lightly on the exhaust on different spots. You should be able to reproduce the rattling sound like that.
Old 07-19-10, 07:51 PM
Czechlex
Czechlex's Avatar
I had Sonnie at Dynamic Auto put my header on my 01 GS3 and no CEL problems ever! All my O2 sensors are connected and the car runs fine.
Last edited by Czechlex; 07-19-10 at 07:53 PM. Reason: forgot to add model of car.
Old 07-19-10, 09:25 PM
5t341th
5t341th's Avatar
anyone run aftermarket cats? like non-oem part? i got a DTC code for inefficient cat on Bank 1. i wanna know if i replace with non-oe part, will it go away
Old 07-19-10, 09:28 PM
LexFather
Guest
Posts: n/a
My 01 GS has this issue too...will need to replace before emissions time in the winter....$1200 per cat at the dealer is the right quote. They really recommend buying used or somewhere else and let them install to save a bundle.
Old 07-19-10, 09:45 PM
TruPlaya26
TruPlaya26's Avatar
I don't know if this helps but I removed the center cat I believe, the one just after the 2 cats after the headers ...
heres pics:
Here's everything before the surgery ...
After a little cutting action ...
And finally the replacement, all custom ...
It only cost me $50 to have the shop do it! What do you think?
Old 01-23-11, 07:21 PM
CMWis300
CMWis300's Avatar
Po430 code fix. I battled this for a month and came up with a good cheap fix. I had the po430 code on a 2002 IS300. The cheap fix is to tie both of the bank 1 & 2 sensor 2 input wires at the ecu to the bank one sensor 2 output at the ecu. I used one gold plated butt splice connector at the ecu plug. You must leave both sensors and wiring in place good or bad for the heater load and bank one o2 sensor 2 must be good. You can find the pin out wiring diagram online at o2simulator.com. I feel as though it is a design flaw that everyone over 100K will have to deal with. You can spend thousands on cats and o2's and labor or a 20 cent butt splice connector. Hope this helps everyone.
Old 01-24-11, 11:37 AM
92sc300nj
92sc300nj's Avatar
i would 100% go with a dealership one over an aftermarket one, but sometimes like Aristo8 said it could be an exhaust leak causing it. more than likely your cats are clogged and bad though, have your dealer do a cat test to see if its actually going bad that way its on record, btw bank 1&2 are the same one pipe so your getting both actually you cant get them seperate
Quick Reply: Catalytic Converter on the rocks
