How To Replace Side Marker Lights???
Old 06-23-02, 06:10 AM
FILIPE
FILIPE's Avatar
Default How To Replace Side Marker Lights???
CAN ANYONE PLEASE TELL ME HOW TO DO THIS? SEND ME A PM. I HAVE CLEAR CORNER LIGHTS OR SIDE MARKER LIGHTS, AND DON'T KNOW HOW TO REMOVE THEM. HELP!!!!!
Tilksh (11-11-19)
Old 06-23-02, 09:30 AM
LexusL
LexusL's Avatar
there should be a screw next to the wheel to pull out the mud guard then you use a wrench to unscrew the sidemarker kinda blindside when u do it cause u can't see it just feel it only.
kdrisk (03-07-20)
Old 06-23-02, 07:46 PM
roenick7
roenick7's Avatar
just got done. You will need a 10mm socket (1/4" size) I used the smallest because it is tight. Remove the 10mm/phillips nut at the front of the wheel well ( about 13"-15" up). You can also remove the bottom screw if you have big hands. Bend nack the wheel well to get you hand inside; there are 2 10mm nuts to remove losen w/ wrench then I just spun them off with my fingers and socket. EASY and FAST.
Old 07-06-02, 07:58 PM
Blanco
Blanco's Avatar
Talking Good pics, but sketchy directions
Try this linkhttp://www.angelfire.com/dc/bananags...ide/index.html
Use the 10mm wrench. The plastic fenderwell moves pretty easy. A deep socket ratchet would be the fastest, but didn't take long doing it by hand. Hope this helps. PM me if I can be of more help.
Blanco
Old 07-06-02, 09:18 PM
Received 2,127 Likes on 1,379 Posts
Someone on another thread said it's easier just to take the fog light out and reach in.
Tilksh (11-11-19)
Old 07-07-02, 04:02 PM
Blanco
Blanco's Avatar
Cool Whatever works
Never tried it through the foglight. Going thru the fenderwell wasy VERY easy, and VERY fast. Both lights were replaced within 20 minutes.
Old 07-07-02, 05:39 PM
VVT-i
VVT-i's Avatar
Remove the fog light is easier, two screws and three minutes. Thanks bit.
Old 07-13-02, 06:46 AM
FILIPE
FILIPE's Avatar
okay thanks, didn't think to do it thru fog light, but will try
Old 07-13-02, 12:42 PM
Rockero28
Rockero28's Avatar
Thumbs up clears
I can go through the fogs and do it while I am waiting on a red light...
Rock
Old 07-14-02, 10:08 PM
MarkMacGS4
MarkMacGS4's Avatar
Going through the foglight was a breeze. Remember not to touch the bulb directly or get any type of oil or dirt on it or it will burn out. AND also check to see that the light isn't burnt out before closing up shop and tightening all the screws! Just a bit of advice from someone who had to do all that.
BTW I replaced the stock bulbs with white ones that match the HIDs. Looks great IMO.
Old 07-14-02, 10:34 PM
futuregs
futuregs's Avatar
I just bought mine and did them this weekend. Took me about 10 minutes, put some nice Polarg Super White M4's in there too.
Old 07-14-02, 10:54 PM
Rockero28
Rockero28's Avatar
Default Sidemarkers
Well these you need not worry about touching directly. They are not like the 9006 bulbs that are used for the fogs/headlights. I carried my piaa wedge bulbs in my pocket for a week before I finally got around to installing them them. However..... I decided to go back to the stocks.
NE1 want to buy them?????? I will sell them.
Rock.
Old 03-07-20, 03:33 PM
kdrisk
kdrisk's Avatar
Thanks! I never would have looked there.
Yes it is all by feel, hard to manage with larger hands.
ScottURnot
Performance & Maintenance
50
08-08-17 10:18 PM
Matroushi
06-30-17 08:13 AM
NemeGuero
09-18-10 01:10 AM
TRD_Power
Lighting
07-11-05 02:54 PM
Vegassc400
SC- 1st Gen (1992-2000)
21
06-17-03 08:47 AM
Quick Reply: How To Replace Side Marker Lights???
