What is this sound? (See Vid)
Old 05-15-10, 03:05 PM
abailey269
abailey269's Avatar
Default What is this sound? (See Vid)
Hey guys, do you have any idea what this crazy sound is that's coming from my dash? Its related to the AC system: sounds like birds are chirping and is annoying as hell.
http://www.youtube.com/watch?v=V5e1D_pfDIs
Thanks!
EDIT: Be sure to turn your speakers up or get real close to them to be able to hear over the road noise. Its hard to catch this sound so I had to get it when it happened.
Old 05-15-10, 04:51 PM
Rich23
Rich23's Avatar
Im not hearing anything, it sounds like air to me... Maybe its just because I am listening on my laptop! I know you said birds... just dont hear it!
Old 05-15-10, 05:15 PM
iloveGS4xx
iloveGS4xx's Avatar
idk man maybe some birds ouside but dont hear anything inside!!
Old 05-15-10, 05:22 PM
Mr Jokster
Mr Jokster's Avatar
Yup I hear it... those with laptop put your ear to the speaker, thats what I had to do LoL. I havent the slightest clue how the car is built back there, but sounds like a fan that needs some lube.
Old 05-15-10, 05:25 PM
iloveGS4xx
iloveGS4xx's Avatar
freggin Laptop ,,,,,,,my bad just listen over again and i heard that noise sound !!!! Agree with Mr. Jokster
Old 05-15-10, 05:54 PM
swat1727
swat1727's Avatar
can anyone do a write up on how to lube the fan?
Old 05-15-10, 10:50 PM
EN_VY
EN_VY's Avatar
Lol at the related videos
Old 05-18-10, 08:10 AM
abailey269
abailey269's Avatar
Where is the fan that needs to be lubed? Is this a common issue with the GS?
Thanks!
Old 05-18-10, 08:19 AM
Infamous 1
Infamous 1's Avatar
I believe its the fan behind the glove box.
Open you glove box
Remove the insert to gain access to the filter panel
Remove the filter panel
Remove the filter
Reach your hand in there and remove any debris
Change your filter if dirty
This should fix the problem.
EDIT: i just remembered, back in my bimmer days, this noise was a sign of having to replace the entire fan. Which, let me tell you, was not a fun job!
Old 05-18-10, 09:09 AM
abailey269
abailey269's Avatar
Open you glove box
Remove the filter
Thanks so much for the tip, I'll give that a shot. I hope its not the fan/fan motor its self, I guess I'll just clean it out first and go from there.
Old 05-19-10, 07:34 AM
DarKnight
DarKnight's Avatar
I couldn't hear it at first because of the birds chirping outside my window lol. After I put the computer speaker to my ear I can hear the chirping. It's a nest in your engine bay. Don't fix the problem just let them live their.
Old 05-19-10, 10:56 AM
sakataj
sakataj's Avatar
Thanks!
thats not a fan OP....my drivers side servo is out and i have the same "chirping".
u got any issues with your heat or a/c? any noises on startup? this sound actually coming from behind the glovebox OP?
Old 05-19-10, 11:21 AM
Wringo
Wringo's Avatar
Default Chirping sound?
I honestly don't believe it's your a/c? Drive your car with the a/c off and see if you still hear it? I think it's your springs/shocks or coilovers that sound as if they need to be greased? I have the same sound in my rear as I'm driving and the coilovers are flexing? Check it out and let us know?
Old 05-19-10, 11:38 AM
sakataj
sakataj's Avatar
u might have the same sound....but its not coming out of your dash....
i cant tell though....as Darrel said drive it without the air on....ALSO try just turning the key over without starting it and see what u hear
Old 05-19-10, 11:51 AM
chuckb
chuckb's Avatar
it's the servos in the ac going bad. mine has done it for years now. it will keep getting worse.
I also have a new noise back there.........
Quick Reply: What is this sound? (See Vid)
