bass rattles
Old 05-09-10, 03:02 PM
robertoyou
robertoyou's Avatar
Default bass rattles
what rattles do you guys have from turning up bass (factory or after market)?
i just did a bandpass ported through my rear deck where stock sub was, and it sounds a whole lot better- more bass in cabin of car and a lot less rattles than before, but theres just ONE rattle that is there even at low volumes.
its in the back left side of the car, on the left side of the trunk. it sounds like its coming from the bumper or the exhaust or maybe somewhere inside the trunk where the jack is. i cant figure where its coming from or how to stop it.
any of you have had this specific rattle that you got rid of?
post any other fixes to "bass rattles" so we can all see them too =)
Old 05-09-10, 07:50 PM
AsGs300
AsGs300's Avatar
try dynomatting where the spare housing is,
Old 05-09-10, 08:34 PM
robertoyou
robertoyou's Avatar
ive dynamatted it a little bit (didnt have much left after doing the doors).
but it doesnt see to come from the spare tire area.
anyone have experienced and fixed this?
Old 05-09-10, 09:03 PM
SoCal Cyco
SoCal Cyco's Avatar
mine rattles from the center seat belt that is hung from the rear deck lid. i just turn it up though. hehe
Old 05-09-10, 09:10 PM
AsGs300
AsGs300's Avatar
best way not to hear ratteling, except when your out of the car , sounds like pots and pans
Old 05-09-10, 10:49 PM
lilsharky
lilsharky's Avatar
mine rattles on right bumper..but i dunno if its because of the 2 12s or not try pushing in your bumper to see if it still rattles
Old 05-09-10, 10:56 PM
sam430
sam430's Avatar
next to the sub, if you look underneath, there is a square plastic box. that thing rattles even with little bass.
Old 05-09-10, 11:01 PM
bigguppy
bigguppy's Avatar
Just remove it. Your seat belt will be expose but the noise will be gone. Way to do it is by removeing the back deck lid.
To OP: check underneath your car for any broken or loose tabs/screws. Try holding your bumpber here and there to test for rattles. Also might want to remove the carpet and check for and loose items.
Old 05-10-10, 01:42 AM
JeffTsai
JeffTsai's Avatar
No, it's actually something else lol. The GS trunk has vents on the both of the quarter panels behind the bumper. They have a flap on them and they will buzz or vibrate when you have big subs. I think the vents are for in case someone gets trapped inside so they don't suffocate. You can get them welded shut if you're sure nobody will get locked in your trunk
Old 05-10-10, 07:46 AM
DarKnight
DarKnight's Avatar
If someone does get trapped, there's the emergency release lever inside. Plus it's glow-in-the-dark so they shouldn't miss it unless they're sleeping lol.
Old 05-10-10, 07:58 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
The license plate rattled on mine - dynamatted the back of it heavily and fixed the issue.
Old 05-10-10, 10:27 AM
sakataj
sakataj's Avatar
i actually cut a hole INTO the rear deck through the metal of the rear deck and then through the interior part of the rear deck as my port was to close to the rear deck.
u mean like this?
thats what i did ben, lol
no the part jeff means this white piece in the corner
EDIT: just realized what you meant after reading kyles post and re-reading yours...btw the glow-in-the dark emergency trunk release WASNT mandatory till 2001 so any GS from 1998-2000 DOESNT have this piece.
regardless here is a pic to show one of the vents
yeah i did that too lol
Old 05-10-10, 01:43 PM
Kyle Harty
Kyle Harty's Avatar
I was thinking the same thing Jeff was from your description, I don't have bass in the GS yet but I've had this happen in previous vehicles. You might be able to glue it shut with a bunch of hot glue or something; haven't seen the vent in the GS other than Brian's picture to tell whether you'd be able to get at the actual vent pieces that are making noise.
Old 05-10-10, 04:11 PM
RoboRam12
RoboRam12's Avatar
Cardboard works well too if you wedge it in there before tightening all the screws. This is something that plauges my car too, I just have never bothered to really look into it. It doesn't rattle outside so it only bugs me.
Old 05-10-10, 06:37 PM
ChampGS3
ChampGS3's Avatar
The vents in the trunk are there for proper cabin "vent"ilation. So when you turn the hvac fan on fresh, and it draws in air from the outside, it has somewhere to go. Imagine how weak the air would blow, if at all, if it were forced to blow into a nearly airtight cabin. That would be like trying to blow into a balloon that is fully inflated, see what I mean?
Quick Reply: bass rattles
