VVT System Malfunction
Old 03-11-10, 08:24 PM
ANTW1
ANTW1's Avatar
Default VVT System Malfunction
1998 GS400 200K
ODBII CODE P1349
From what i've researched on the web, I need to check the following:
Valve timing, vvt controller, OCV, and ECM.
Can anyone tell me how to check these and where their locations are?
My car was misfiring and now doesn't even turn over.
Any info would be greatly appreciated. Thanks.
Old 03-11-10, 08:37 PM
GS_OREO
GS_OREO's Avatar
Hmm.. with 200k did you do your timing belt ? Since its not turning over, check to see if your T-belt snap.
Old 03-11-10, 11:04 PM
MrExecutiv
MrExecutiv's Avatar
Most probably its your timing belt, if its not turning over. I would check that first.
Old 03-12-10, 04:26 AM
Clifton
Clifton's Avatar
Search under my name, I don't have many posts. I explained it to someone a few weeks ago. If you are mechanical and have tools it's an easy fix when doing the timing belt. If you can I can send a pdf.
Old 03-12-10, 04:50 PM
ANTW1
ANTW1's Avatar
Clifton, yes, please send me the pdf.
Thanks.
dbarber45
RX - 1st Gen (1999-2003)
14
10-18-16 11:41 PM
BDSL
06-02-12 03:14 PM
MuGGzyx
Performance & Maintenance
05-20-10 08:45 PM
sivikvtec
03-18-09 02:19 PM
Sleam
IS - 1st Gen (2001-2005)
02-21-07 10:35 PM
Quick Reply: VVT System Malfunction
