how do you know when your ball joints are worn out
for me, it was when ever i drove over the littleist bumps, it sounded like my suspension was going to come through my hood. luckly i replaced them cause they were done for.
suggestion.... replace them!!!
A few symptoms of a bad ball joint are a somewhat heavy steering wheel, creaking and popping when turning steering wheel, pops and such when going over bumps, and the wheel doesn't center/swing back on its own. You may get no symptoms at all; it could just fail. If they have anywhere from 75K-90K miles on them, I suggest you replace them before you end up smacking yourself on the back of the neck.
Not a problem. I saw a 99 GS go down the other day here in the Boston area. Pulled over to help/see what happened and it was the ball joint that failed at 96K miles.
If they had only been a member of CL they would have known. *sigh*
Thanks guys.
You guys been very helpful. I'm just curious to know the symptoms before it breaks down on me. I'm picking up a new set of rims and switching out my brakes too. While i'm at it. i'm going to check out the ball joints too.
-Another thing, isn't there like an add on bracket that doesn't create so much stress on the ball joints?
PS:
i'm putting a lot of work into my car this month. I'll show you guys updates. few new things are coming in; custom lights, rims, etc....
PS:
I've seen 4 or 5 GS's in my area in the last few years, a couple weeks ago I saw a GS on a tow truck so I went by and sure enough a front wheel was turned sideways in the wheelwell. When I recognized the GS tails on the flatbed I wasn't the least bit surprised that the ball joint ended up being the culprit.
