Car won't start - advice?
Old 03-05-10, 10:48 AM
werewolf
werewolf's Avatar
Default Car won't start - advice?
Hi
I did search on this and couldn't find a thread with the same symptoms.
How long it's been happening
1) Once last night where I couldn't start the car with the 1st 3 key-turns
2) This morning the car wouldn't start with 1st 2 key-turns
What the car does
1) with the key in the ignition and foot on the brake, I will turn the key to start the car
2) With the failed key-turns, the car makes ZERO noise (no cranking, whining at all)
3) When the key-turn works, it sounds completely fine and runs normally
Other details
1) I cleaned the MAF sensor last week
2) I applied some battery terminal grease last week to the battery
3) The car doesn't throw any codes / has no warning lights on
4) Battery is only a year old
Thoughts?
Thanks in advance
Old 03-05-10, 10:56 AM
shvc1991
shvc1991's Avatar
Have you checked the battery connections? They may be loose.
Old 03-05-10, 11:15 AM
jadu
live.love.laugh.lexus
jadu's Avatar
jump start?
Old 03-05-10, 11:22 AM
werewolf
werewolf's Avatar
Originally Posted by jadu
jump start?
The car eventually starts (so far) and the battery is pretty new
Old 03-05-10, 03:00 PM
PushinLEX
PushinLEX's Avatar
check the alternator and the starter as well.
Old 03-05-10, 07:41 PM
SirBev
SirBev's Avatar
Okay could be your starter, or it could be that your neutral stafety switch is going it's not the battery or it wouldn't start after you turn the key a few times unless you heard it struggling to bump over. So the next time that it doesn't turn over when you attempt to start it, try it shift you gear selected in park again and them see if it starts right up.
Old 03-05-10, 08:04 PM
werewolf
werewolf's Avatar
To be clear, if the car doesn't start...
1) shift out of park to drive
2) shift back to park from drive
3) retry?
thanks
Old 03-05-10, 08:07 PM
BP_VVt-i
BP_VVt-i's Avatar
Yea def sounds like a starter issue. If when you turn the key and it clicks once then its your starter.
Old 03-05-10, 08:20 PM
SirBev
SirBev's Avatar
You don't have to even shift it just tap it over more ( in the direction that it would be in when you just slide it into park ) if you have a starter problem it will make a click and not start, or it won't turn over at all in this case you could ( tap ) * not bang on the starter however from what you discribed it's not the starter.
Old 03-05-10, 08:34 PM
fasted1953
fasted1953's Avatar
It sounds like the problem I had with my starter. Turn the key, nothing. Turn the key again, cranks and starts fine. The starter is in the valley between the cylinder heads(assuming its a v8), so I dont think there's a way to tap on it, like we'd do on an old american v8. I had the lexus dealer change the starter, and I'd never let them touch the car again. The first replacement starter was bad and they gave it back to me anyway. Plus they broke several other parts and didnt tell me. Left it all up to me to discover. Next time, I'd use my local lexus mechanic who rebuilds starters, normally just need brushes, instead of replacing the whole starter.
Old 03-05-10, 11:13 PM
bigguppy
bigguppy's Avatar
Did this happen before you clean your MAF sensor? If so maybe somthing may of went wrong? If so try going back for another spray and let it sit for a bit before trying to start up. GL
Old 03-06-10, 12:29 AM
VipDout
19x11.5 -51
VipDout's Avatar
I had about 3-4 click before starting for couple months ... and then one night before you see the picture ... 75 clicks until it started .. I was like omg..
then I did the gs400 starter...
clear your schedule ...
Old 03-06-10, 03:58 AM
eclipse604
eclipse604's Avatar
similar thing happened to me. replaced the starter contacts/brushes and it worked like charm. you may or may not need to replace the entire starter.
Old 03-06-10, 05:59 AM
flexspeed
flexspeed's Avatar
supz... i have this issue but mine is a gs300, if its clicks.. it can be more then just a starter... it can be teh cables also..yea i check the starter first, if thats bad, then u know what to do.. if its check out good, then i go with the cables... what year is your car...n how many miles? what state u from? why im asking is that if u live in snow area or beach... cables goes bad like dirty or corroded and so quicker then other....cables are cheaper then replacing starter or sensor first unless for sure u know which is bad....hope this help...
Old 03-06-10, 05:46 PM
werewolf
werewolf's Avatar
Hi all
Thanks for all the feedback.
So far
1) I've replaced the starter relay so I know that's good (goodbye 80 bucks)
2) The starter actually spins free when I turn the key (slight noise, no cranking/catching sounds)
The problem is the starter (near certain now) but how do I get the car to start so I can get it from its garaged spot to the garage now? We're talking at least 10 miles.
Price quotes I've gotten so far
1) 625 from independent (325 parts + 300 labour for 5 hrs)
2) 1300 from a Toyota dealer
3) 1500 from the Lexus dealer
I live in SoCal and the car here been for its entire life so I am guessing the cable is OK.
Quick Reply: Car won't start - advice?
