Ngk iridium ix spark plugs
Old 01-12-10, 04:20 PM
GS_OREO
GS_OREO's Avatar
Default Ngk iridium ix spark plugs
I have a 98 Gs300 with 150k, and I just install those plugs in my car. Then I realized when I removed the plugs, the plugs were Denso with dual tips on there. I had a single tip.
I installed them anyways and I did notice a slight power loss, or It could just be in my head.
My question is..
Do you think it'll affect the perfromance/gas milage greatly ?
Old 01-12-10, 04:31 PM
GS4_Fiend
GS4_Fiend's Avatar
The iridiums should be single head iirc. The dual heads I think are platinum.
Old 01-12-10, 04:33 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
NGK iridiums i beleive for the GS's
www.sparkplugs.com
Old 01-12-10, 11:53 PM
a#'z
a#'z's Avatar
Ngk is fine, Denso is more of Toyota, and NGK is more of honda, that's what i have noticed, but i have NGK Lazer Iridium on my gs. =]
Old 01-13-10, 11:05 AM
o6spdracer
o6spdracer's Avatar
There have been some good reviews on the Torque Masters. I'm debating between those and the NGK Iridiums as well.
Old 01-13-10, 12:02 PM
DJ420
DJ420's Avatar
Nissan also uses NGK spark plugs for OEM. NGK and Denso are very comparable and similar. I am running NGK Irridiums in my GS4, with no worries!
Old 01-17-10, 05:20 PM
GS_OREO
GS_OREO's Avatar
Ok cool. I replaced all the plugs. My next step is to replace the valve cover gasket. When I pulled the plugs out, they were all saturated with oil. Is that because the valve cover is leaking ?
Im guessing it should affect gas milage because all that saturated oil on the plugs affect the spark.
Old 01-17-10, 06:16 PM
tmf2004
tmf2004's Avatar
Can you PM the part number for the plugs you used? Sparkplugs.com has so many different ones to pick from.
Thanks
Old 01-17-10, 10:39 PM
Curry
Curry's Avatar
You should have done the valve cover first and then put the new plugs in... It sounds like it is leaking from the way you describe it.
Old 01-19-10, 08:53 AM
Frankdorn
Frankdorn's Avatar
I'm having the same valve-cover leaking problem. Grab new grommets and gaskets from Lexus and rebuild 'er, swap plugs when you're done.
Old 01-19-10, 09:03 AM
GSteg
GSteg's Avatar
It's the spark plug gasket that's leaking. But either way you have to replace the valve cover gasket when you pull off the cover.
is3504bao
09-23-22 11:01 AM
Jimbo2828
Performance & Maintenance
06-11-05 04:26 PM
ted920
Performance
11-11-03 12:06 PM
indypwr
GS - 1st Gen (1993-1997)
12-17-02 08:19 PM
Quick Reply: Ngk iridium ix spark plugs
