DIY Seatbelt Cleaning
I am a new owner of a 10 year old 2Gen GS. I have a tan interior and that means tan seatbelts. I knew I should have bought ebony...
I was appalled at the grime on the front seatbelts so I got down to brass tax today and cleaned them.
1. Use Dawn Dish Detergent (blue in color). This detergent is different than the others as it is more of a stripper. Those of you who claybar their car know this detergent works very well in removing your wax/polish and build up.
2. Oxy Clean powder.
3. Clean cotton towel and a clean cotton wash mitt.
4. Plastic wire brush.
Start by filling up a medium size bowl with hot water, 1 tablespoon of Dawn liquid and 1 tablespoon of oxy-clean.
Fill up another bowl with clean hot water.
Stretch out your seatbelts and bring your seats all the way forward. Lock the belts with the buckle at the top so they don't retract while cleaning.
Get a cover for your seat while cleaning and drying (I did one side at a time).
Start by wetting the was mitt in the bowl with the cleaning products and wet the entire belt. Stretch the belt out so it is taut while cleaning. Do your best to get the liquid to penetrate the entire belt.
After it has soaked for a few minutes, Go ahead and start scrubbing the belt with the wash mitt 6-10 inches at a time working from one end to the other. Take care to rub the sides a little extra as mine showed more grime on the edges. Rinse the mitt every minute or so.
After 5-10 minutes with the wash mitt, grab your scrub brush and with the same process scrub the entire belt, both sides.
Next step is to grab your clean cotton towel and get it wet/damp with the clean hot water. Start from one end to the other and scrub out all the cleaning liquid taking a little extra time around the edges. You'll notice if your using a white towel the residue that you are removing.
Now, don't forget the buckles, they are dirty! grab some paper towels and windex and get out all the grime in the tracks off the buckle where the belt slides back and forth. If you don't do this step you risk getting more dirt on your belts and especially when its wet it will set in.
Let dry for 2 hours and don't let them retract during drying.
I only wish I had taken before photos. My belts were very dirty. The end result was no dirt and they actually shine like, well almost new!
Hope this helps as I have read many posts about cleaning the belts and frustration with the outcome. This works very well....
Angelo
Club Lexus Vendor Marketplace
06-17-10 12:56 PM
